- Thank you received: 155
Westland Whirlwind... test 2.. another crash arriv
- Cpl Jones
- Senior Member
- R.C. aeroplane collector & flyer. FPV lover..
Damage report... both nacelles ripped off, broken wing. I shall repair her and try again... I'm determined to get a nice vid of her flying... she's so heavy though!
'1/2 lb pork and a slice of haslet/' Cpl Jones.
Jah Baga I... thanks!.
Hmmm
If that was full power I think you need more or loose some weight, or both!
I would also recommend counter rotating props as well. From my own experience it really improves things at high power and low speed. i.e. a hand launch!
Seriously, I think Quorneng is dead right with his post, it never seemed to attain flying speed.
- Thank you received: 14473
- Cpl Jones
- Senior Member
'On parade Troup!' Cpl. Jones
- Cpl Jones
- Senior Member
- Cpl Jones
- Senior Member
It would have gone better with mo' throttle... maybe.
Cpl Jones
Please don't guess what current/watts/volts you are drawing, that is the shortest route to conflagration!
On the bench, a wattmeter will tell you exactly how much power you have.
You need AT LEAST 100 watts per pound (220 per kilo) on this kind of model.
Don't forget, the prop diameter and pitch decide how many watts the motor pulls. The voltage to the motor decides the rpm's, unless you get to silly large props, when things will start to melt, because the motor will just suck more and more amps in the effort to turn at it's designed rpm's!
To get 550W you would have to pull 550/10.5 = 52A, I am not sure a 40A ESC would allow such a current for long!
So unless I have got the figures wrong you are actually running rather less than 550W per motor but as Eric says without a meter it is not possible to determine what is the total power available.
