Own Design
25 Oct 2014 19:42 #1 by Ex-Member
Own Design was created by Ex-Member
spent a couple of hours over the last 2 days and knocked this up.
long way to go yet before i can try it out.
doing little bits while i wait for tsr2 bits to dry.
all good fun. :P
25 Oct 2014 20:03 #2 by Garry Pollard
Replied by Garry Pollard on topic Own Design
Dont you just love Tony s expression "Just knocked this up", it would take me a month to do that :( :(
26 Oct 2014 07:14 #3 by Ex-Member
Replied by Ex-Member on topic Own Design
Just make sure you don't get bored Tony........ :lol: :lol: :lol:
26 Oct 2014 07:49 #4 by Ex-Member
after sticking the motor and battery in the nose, i have decided that the servo's need to go in the tail to help balance it better.
so i have to take out all the snakes later today.
26 Oct 2014 16:23 #5 by Ex-Member
servos are in the tail.
canopy/ battery hatch made.
started constructing the cowl.
28 Oct 2014 15:44 #6 by Ex-Member
where i am today.
09 Nov 2014 16:37 #7 by Ex-Member
decided i best do some to this.
gluing the wing tubes into the wing cores, yes i have to cut the middle bit of tube out yet. :P
10 Nov 2014 15:15 #8 by Ex-Member
wing tubes fitted and the wings actually fit for a change. :)
can start cutting and gluing the ribs on tomorrow and maybe get them sheeted, we shall have to see.
10 Nov 2014 16:51 #9 by Modelflyer99
Replied by Modelflyer99 on topic Own Design
Looking good!
To me, it has the look of some of the classic aerobats of the 70s
Andy
10 Nov 2014 17:30 #10 by Ex-Member
that was the idea sir.
though i hope to have a trick up my sleeve if it works that is. :P
11 Nov 2014 16:38 #11 by Ex-Member
wings getting sorted.
keeping it simple this time.
root rib, main spar, balsa trailing edge.
the a single sheet of 3mm over the top and sorted.
got to sort the servo positions tomorrow and then i can do the same with the undersides.
12 Nov 2014 15:11 #12 by Ex-Member
ran the servo wires up the fuselage to the nose area and then started sheeting.
it has stiffened the fuselage up nicely.
aileron servos are glued into the wing now, next job is to sheet the underside of the wings and make up the rudder, elevators and ailerons.
13 Nov 2014 13:55 #13 by Ex-Member
cant get going today for some reason.
13 Nov 2014 14:14 #14 by old fart
Replied by old fart on topic Own Design
Nice build Tony. :)
Shame about the undercarriage. [badass]
14 Nov 2014 16:56 #15 by Ex-Member
hello
wings are all sheeted, wing tips fitted, aileron servos in and working.
and i even programmed the dx9 correctly. :cheer:
now if i build this right it might do a vertical take off. :unsure:
Time to create page: 1.837 seconds
