- Thank you received: 200
DH53 Hummingbird
- Modelflyer99
- Senior Member
As most of you probably will not be familiar with these kits, a few words about them may be in order. Stephens Aero is an American kit manufacturer who produces a range of laser cut kits of both stand-off scale and non-scale indoor models. The models are all designed to take the Parkzone/Spektrum Rx/Servo/ESC units, and are the best kits I've ever come across. They are fully laser cut from balsa, with some ply parts where necessary. The fit of the parts is IMHO exemplary, and these are models that can be built mainly in the hand, and then glued with thin cyano.
A typical sheet of laser cut parts
And the reverse side
- Modelflyer99
- Senior Member
So, this is the first side. As you can see, you have to add some strengthening uprights to it (more on that later)
And then you add the central crutch and the first of the formers. The position of all the formers is preset with laser cut "slots" in the sides and the central crutch
And then the ply battery mount area...
- Modelflyer99
- Senior Member
- Modelflyer99
- Senior Member
- Modelflyer99
- Senior Member
As with the side panels, there is a strengthening cross piece to add to the bottom.
Here is the bottom decking as it comes out of the sheet. You can see that there are 2 lightening holes cut with the laser that you have to remove. The rear hole is not just oval though, there is a dovetail cut into each side.
This the pieces removed from the holes
And here is the crosspiece removed from the waste
And finally, the crosspiece fitted to the bottom decking. It is so well designed, you just press it into the recesses, and glue it with a dot of cyano.
- Modelflyer99
- Senior Member
What's the span and which colours will you be using?
sad about your friend Andy.
- Modelflyer99
- Senior Member
Andy, WOW, to think I'm 'talking' to some one who has flown the original plane, I'm honoured! :ohmy:
The wingspan is a tad less than 27", and should weigh in the region of 70gms. I will be doing it in the blue and silver colours that G-EBHX was painted in. Actually, finding any alternative colours has been quite frustrating, the only other example (in colour) I have been able to find is an example done all over silver with RAF markings!
Andy
- Modelflyer99
- Senior Member
I've built a few of them now, and they all go together very, very well indeed. Some of the simpler models can be built in a couple of evenings.
Micron Radio Control are the stockists in the UK
Andy
- Modelflyer99
- Senior Member
2 ply formers fitted at the front of the wing aperture sandwich another piece of ply which mirrors the shape of the U/C wire (a V shape). The wire will then plug into this slot and be secured by a final V shaped piece of ply. You may just be able to make out the U/C slot here
and here
- Modelflyer99
- Senior Member
- Modelflyer99
- Senior Member
The instructions tell you to moisten one side of the sheet and to gently bend it into shape (standard stuff!), but muggins here got a bit carried away and broke this piece in twain (There wuz a fault in the balsa, honest yer 'onour!) :blush:
Now, these kits are cut from a funny size of balsa sheet (1/20th) so to cut a replacement part from my stock of 1/16th would have meant a fair bit of sanding, and 1/32nd would have been too thin
Luckily there was enough spare at the end of one of the laser cut sheets to cut a new one.
Not quite as good as the original, but not too bad
Next the stringers were added at the back
- Modelflyer99
- Senior Member
