Keil Kraft Bantam
Originally designed and drawn in 1955 by AH Hatfull it was initially called Anzac but due to pressure from the new Zealand government it's name was changed to Bantam.
Looking at the plan it's quite clear the original would have had a very short lifespan, it's built like a rubber powered Model, a couple of 1/8th spars in the wing and tiny braces are ok for a model powered by a couple of strands of rubber but wouldn't last long with diesel power even though the plan calls for that to be supplied by such mild engines as a ED baby, frog 50 or Albon Dart or Merlin.
First task is to redraw the front end as I plan to use this lovely little used ED Bee series 2, swings a 8x4 and has a lovely exhaust crackle.
Very 'period'.
I would have thought using an ED Bee you will have to strengthen a bit more than the nose as you will be installing twice the recommended power of say a Frog 50 although having said this I note the series 2 Bee produced a peak of 0.068 hp (50.7 W) according to the 1955 Aero Modeller test.
It does show how far things have come as 50W (7A on a 2s) would be a pretty modest figure for even a small brushless electric RC plane today. In fact such a motor, 10A ESC and a 1000 mAh 2s would be no heavier than the Bee!
You really need to take a look at the plan, it's very odd in places, the wing and fuselage are very lightly built but the fin is built like a brick outhouse!
The notes show the prototype weighed 6.7oz with a Albon Merlin.
Don't think I'll get near that but I'm sorting of aiming for 10oz, I've just been given some 6 micron Mylar that I'm going to cover it with ( double covered with tissue) that should be fairly light and puncture resistant.
Oh and your right about the Bee, it is rather lacking in umph ( being 1958 and in such nice condition I only run it rich and under compressed) but it is torky.
Had a look at the plan.
The fuselage formers look to be drawn 3/32 whereas the ribs are 1/16.
I suppose the tail fin is robust simply because the fuselage terminates short so it in part supports the tail plane.
Good lick creating all those 1/8 x 1/8 closely spaced slots in the lower formers!
Finally with a heavily under cambered wing section I suspect it will tend to be a 'one speed' plane with a sensitive CofG position that has to be 'just right'.
got a few jobs on this morning but hopefully I'll start cutting later...watch this space.
They are so close together that I bet 1/16 sheet would actually use less wood and probably lighter. It might be a bit more difficult to apply but then I suppose Albert H (an interesting story) was very much a 'stringer' man.
- Thank you received: 14470
Didn't get a awful lot done yesterday, 6 nations rugby got in the way! I did however get the first 2 formers cut, cut from "gabon plywood ", noticeably lighter than birch ply but just as stiff, local model shop put me onto it.
Years ago I dabbled in miniature wood carving and bought a set of tiny chisels and there what I use for notches, one on the right has been ground to 1/8th", one on the left is a standard 1/4" job, razor sharp there perfect for tricky little jobs like this.
I added brass end caps that allow me to use a jewellery hammer if needed.
Very neat but I am pretty sure Gaboon Ply is heavier than even the hardest of hard balsa.
just realised I need to notch the spine!!!
6" rule for scale ( very worn, had it since I was a apprentice.)
As it is not really structural and if you could find light enough balsa block you could actually make the underside solid and simply sand it to shape. You wouldn't need any of those little formers either.
Well last night I was offered a new in box and never run DC Dart ( Albon in all but name), Ive said yes to it as frankly it was a bargain,so my question is do I run it all? do I re-adapt the model in order to accommodate a engine it was originally designed for or do I carry on and use the Bee? It does look rather big when offered up, the fuselage while deep is very slim......
My view is leave the Bantam as is.
With only 0.5 cc you really will have to be wary of weight.
Ok for free flight (6.7 oz) but if you get to 10 oz you will need the power of the Bee.
If the Dart is new save it. Its not running it that is the problem but the risk of irreparable damage if it crashes.
