Wots Wot foamie
29 Sep 2025 18:48 #1 by Klipkopwildlife
Wots Wot foamie was created by Klipkopwildlife
My FunCub (second) is now at the stage of circles and figure 8's only, so in anticipation of the arrival of a friend early in 2026 I decided to buy one of these.
It arrived the day before I had to go to Pretoria to repair a roof so has sat here waiting for me to get back.
Thanks: Eric, Flytilbroke, Quorneng, THE BLACKBIRD, jon.in.swansea
29 Sep 2025 21:26 #2 by Eric
Replied by Eric on topic Wots Wot foamie
They fly like a very draggy Acro-Wot  :-)
30 Sep 2025 08:52 #3 by Klipkopwildlife
Replied by Klipkopwildlife on topic Wots Wot foamie
Thank you for those few kind words Eric!
The Ripmax legend had been blanked out.
All very nicely protected
All excellent quality pressings/extrusions
Washing of hands is very necessary before starting a build session!
Thanks: Flytilbroke, Quorneng, THE BLACKBIRD, jon.in.swansea
01 Oct 2025 15:00 #4 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Wots Wot foamie
Nice, i would have recommended the FMS Olympus as that model is so good to fly and it would take anyone up to the next level of flying, it is a smaller F3A practise plane and runs on a 5/6s lipo's, i ran mine on 5s and it had all the power needed, but it flew so true that it gave confidence to go further with one's flying
Im sure you will enjoy the Wots it though
02 Oct 2025 14:02 #5 by Klipkopwildlife
Sadly not available in this country Tony.
Anyway I started by fitting the tail plane and immediately ran into a problem. The keeper for the push/pull rod was binding on the horn
A little work with a file sorted that.
Next up was I had lots of up elevator and relatively little down.
The inner Bowden tube had been left overly long, once shortened I had plenty of movement.
Thanks: Flytilbroke, THE BLACKBIRD, jon.in.swansea
02 Oct 2025 14:16 #6 by Klipkopwildlife
At this stage I decided to do the decorations to minimise hanger rash which is bound to occur when done at a later stage.
There's no glueing at all, it all just screws together with instructions in both English and German, the fit and finish is excellent. At this point I fitted a receiver and found the servos perfectly zeroed. I also added a small piece of tubing as belt and braces to the elevator keeper.
Probably not necessary, just piece of mind.
03 Oct 2025 17:49 #7 by Klipkopwildlife
The last part of the fuselage build is the tail wheel.
So much better than the Funcub which is glued in and detaches every time you ground loop.
Last is the undercarriage
It's not obvious which way round it should go so I opted for the wheels as far forward as possible.
That completed the fuselage section and so on to the wings,
2 servos, 1 plug! and how short is that cable, definitely not fit for purpose, without differential on the 4 (yes read it, four) ailerons the adverse yaw must be huge! I cut off the starboard servo wires and crimped on a new plug. (Port ailerons always go to channel 1, Starboard to channel 5 or 6)
We're now ready to mount the wings
06 Oct 2025 17:20 #8 by Klipkopwildlife
Wings on and everything connected
The upper ailerons are connected via 2mm push/pull rods.
At this point I did a power test, 200watts on a storage charge 3S battery, at 2.42lbs that just over 80watts/lb, hmm, hardly electrifying!
Did I have to say that?
06 Oct 2025 17:30 #9 by Klipkopwildlife
The supplied propeller is a 12x6.
At this point I decided to have a good look at the front end, maybe go up to 4S?
Access is easy, you take the nose cowl off (2 screws) and everything is right there
Quite a lot of side thrust
That looks like up thrust to me, I've measured carefully, assuming that the cowl is square to the thrust line the motor mount is exactly square.
The motor carrier is a very nicely pressed piece of steel plate, 2mm thick
Moving the motor forward or back (more likely) should be easy
Thanks: Eric, Flytilbroke, THE BLACKBIRD, jon.in.swansea
06 Oct 2025 17:36 #10 by Klipkopwildlife
The eagle eyed may have noticed that the spinner is 4mm forward of the cowl, I've decided to leave it at the moment, the fix is to move the motor back (easy) or cut the shaft. She balances 95mm back from the centre point of the upper wing, the rearward balance point. For the maiden I may put a lump of lead in the spinner.
06 Oct 2025 18:19 #11 by Quorneng
Replied by Quorneng on topic Wots Wot foamie
I would certainly leave it. I only noticed the gap because you mentioned it! Is it really as big as 4mm?
07 Oct 2025 08:35 #12 by Eric
The air gap is for motor cooling!
If you need lead, don't put it in the spinner, unless it is perfectly balanced in rotation, that will stress the motor bearings!
If I recall, the metal motor mount is screwed to a small ply plate which is glued to the foam. Any oscillating mass on the bearing will quickly weaken the foam to the point where the motor goes it's separate way.
07 Oct 2025 11:47 #13 by jon.in.swansea
Replied by jon.in.swansea on topic Wots Wot foamie
Tony - are those wheels up to your tufted grasses?  Perhaps on first flight use the fatter beasties from the Cub?  Which might
also give you a bit of weight forward?
07 Oct 2025 12:07 #14 by Klipkopwildlife
Probably not Jon, I was going to 3D print some in TPU
07 Oct 2025 17:51 #15 by Klipkopwildlife
I have a number of 'in spinner' weights, machined by myself, each turned in one setting.
However, as Jon pointed out, the wheels might be a bit small so I'm going to change them for those from a long since crashed Focker Eindekker
Time to create page: 1.040 seconds
