Kit Review, Max Thrust Ruckus (Another Poly Project)
08 Jun 2019 00:16 #1 by Phil Wood
A few weeks ago I was in Steve Webb Models and spotted this Max Thrust Ruckus standing by the counter, I did think about buying it as it was on offer, but it wasn't quite what I was looking for at the time.
When I got home the postman had been with the BMFA magazine and Ann (my missus) had been reading through it. As soon as I sat down she pushed the mag' in front of my face and said, "I want that one" ...... Yes it was a picture of the Ruckus!
For the past few weeks I've had to endure her asking "Where's my model" ?????
Well here it is, you get to peek at the box for now, I'm getting tired, but now that I've started the thread I'll have to finish it. [badass]
08 Jun 2019 10:01 #2 by Phil Wood
Unpacking this thing is a job and a half, even the blocks of foam at each end of the box are held in with double sided sticky tape. :lol:
First impression is great, one thing I hate about some foam models is when they just super press the foam very thin to act as hinges on the control surfaces, I was pleased to see this wasn't the case here, they've fitted good real hinges and the control surfaces are really easy to move ..... These servo's will have an easy life. :lol:
Looks like all the bits are there, shouldn't take long to put this together.
When I lifted the fuz out of the box I noticed the nose was heavier than I expected, .... probably due to this nice meaty looking motor. :)
Inspected for any damage and all I could find is a 1 inch circular blemish on the underside of an aileron, it's generally put together nicely so I'm pleased up to now. ;)
I've been up all night so I don't think I'll finish assembling this today. ...... Pol. [badass]
08 Jun 2019 11:06 #3 by Klipkopwildlife
Replied by Klipkopwildlife on topic Kit Review, Max Thrust Ruckus (Another Poly Project)
That wing joiner looks pretty meaty too. Good to see you back in the saddle Phil.
08 Jun 2019 14:31 #4 by jeffwill6
I have been flying mine for about 5 months found it much more robust than the acrowot Foam-e which I found had a weak undercarriage Which I had to re-glue many times. Probably my landings!!
Jeff
08 Jun 2019 18:11 #5 by Eric
Foamy Acro-Wot - use cheapo plastic bolts on the legs, then they just shear off if the ground jumps up too soon, without ripping the bottom off.
An old straight-blade screwie heated with a flame makes a slot in the stub, so you can unscrew it.
08 Jun 2019 20:24 #6 by jeffwill6
I found it is only screwed to brittle plastic that breaks away and appears to not have any glue on it.
Jeff
09 Jun 2019 02:19 - 09 Jun 2019 02:20 #7 by Phil Wood
Klipkopwildlife wrote: That wing joiner looks pretty meaty too. Good to see you back in the saddle Phil.
There's a hell of a weight in it as well Klip', they say it's aluminium but when I picked it up I thought it was steel. :blink:
It would have saved a few grams if they'd used a carbon fibre tube or rod, but the model is light enough anyway and I don't think it would make much difference to its performance.
Well apart from that what can I say? ...... I was almost hoping to do a kit review with a bit of content, one where I could pick a load of faults and suggest alternatives, but this thing deserves some praise. :cheer:
It went together in less than an hour, and I was supping coffee and smoking myself silly while I was doing it, it was 9 screws, 2 Y leads and fit the prop ...... Oh, and a bit of double sided sticky stuff to hold the Rx in place (which I haven't done yet) :whistle:
I am a bit concerned about the U/C as it's only held in place by 4 small self tappers, but I suppose in the event of a heavy landing it's best for these to pull out rather than rip out half of the fuselage.
It may seem just a little expensive at £150 but it is really well moulded and it's even got lights on the wing tips. :lol: .... these LED's must be bloody expensive! :woohoo:
The motor turns by hand without heavy "klicking" as I call it, it feels really smooth so it's probably one with loads of magnets...... or they forgot to fit any magnets at all :silly: ...... we'll find out when I power it up. :unsure:
I did remember to balance the prop, but it was already perfect.
I've still got to fit a lipo and check the COG, but here's my one bad criticism. Firstly, if they had just rearranged the inside a little and moved the straps further back, the lipo could have sat over the COG point so you'd be able to use batteries of different weights.
But also, .... look at those wing mounting bolts!!!! ..... something has got to be done here or there's a danger of one of those cutting into the lipo and cremating the 'plane. I'll probably fit a block of EPP onto the base of the fuz and sit the battery on that. ;)
In the instructions it shows the battery pushed right forward into the noze, it may need this to get the correct COG but even then it'll be over the 4 bolt heads that you can just see on the left under the motor wires, it definitely just needs a bit of protection here.
But all in all I'm very happy with Ann's model, I'd better get out and maiden it. :) [badass]
Last edit: 09 Jun 2019 02:20 by Phil Wood.
09 Jun 2019 09:08 #8 by crash happy
Looks very nice Phil. You have probably thought of this already but I will throw it in anyway.
I bought a pack self adhesive Velcro. One piece in the battery compartment & one on all my batteries.
Gives me some leeway in getting the CG right with different sizes. It might cover your bolt heads ?
09 Jun 2019 11:51 #9 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Kit Review, Max Thrust Ruckus (Another Poly Project)
You should not be smoking Pol in your condition
I thought you had given it up
BAD BOY
Thanks: Flytilbroke
10 Jun 2019 09:27 #10 by Flytilbroke
You can always trim off the excess protrusion of the wing bolts and round the ends a little.
10 Jun 2019 14:57 - 10 Jun 2019 14:59 #11 by Klipkopwildlife
Never a good idea FTB, the plates on these Lipo's are only microns thick, any pressure and they're gone up in flames taking the model and everything else with it.
I would recommend doing what you've said but then seating the Lipo on a piece of packaging foam.
Last edit: 10 Jun 2019 14:59 by Klipkopwildlife.
10 Jun 2019 22:49 #12 by Phil Wood
Flytilbroke wrote: You can always trim off the excess protrusion of the wing bolts and round the ends a little.
That thought did cross my mind but then I thought of the possibility of a wing bolt vibrating loose. If it was only screwed in a couple of turns it could fall out before I could land the thing.
I couldn't lock them in place because I will have to remove the wings for transport ..... I've got a much smaller car now. :(
11 Jun 2019 09:51 #13 by Eric
I think FTB meant saw off the surplus bolt length, when it is screwed fully home.
So it will still be 'all the way in', but with nothing poking through into the battery compartment.
Don't forget to allow airflow over the battery, if you are using a lot of power for aero's, the pack can get quite warm - even hot - if you are pushing it towards it's max 'burst' power current drain.
Thanks: Flytilbroke
23 Jun 2019 09:32 #14 by Flytilbroke
I agree that some "bed" surface would also help after trimming the bolts flush. This is something I have done a number of times without any problems. Also as is fairly common the "hook" half of Velcro type in the model and "loop" half on all battery's. Plastic bolts can be a tighter fit than metal ones, good in this application and as we are talking battery power there is very little vibration to possibly cause them to loosen
I see Eric also answered B)
27 Jul 2019 14:57 #15 by Phil Wood
Well I did maiden this one a few evenings ago, but not before a few alterations.
I was bit annoyed to find out that the manufacturers had issued a report that they'd received a few complaints.
1)The canopy had a tendency to blow off mid flight due to a build up of air pressure inside the cabin.
2) when used with a 4S lipo the ESC got very hot.
Their solution to the cabin pressure was to simply drill a couple of 15mm holes on the underside of the model to release some air pressure.
The ESC problem was a bit different. The model was portrayed in some reviews as being good on a 3S :) .... but a rocket on a 4S :woohoo:
Their solution to the ESC overheating problem was that the holes on the understand of the fuz would allow better air flow & cooling.
Also they reduced the prop from a 12 x 6 to an 11 x 5.5 :angry: .... This would just mean less power!!!!! .... so in other words crap on a 3S and OK on a 4S .... not the rocket I paid for.
Well a lot of chopping was needed but out came the 40A stock ESC and in went a 70A opto one with a bloody big heat sink. (I just happened to have one in stock).
I had to carve a hole through from underneath the motor to make a space for this heat sink, and to allow decent air flow. All the wiring had to be re-done as well. :angry:
Yes I can see the bare wire, don't worry, I cut all this to length, heat shrink it, and fasten it all down neatly. :cheer:
The ESC fits great and gets a howling gale over it.
More to come. .... Pol.
Time to create page: 1.182 seconds
