Glass cloth covering
  • Pylonuk
  • Pylonuk's Avatar Topic Author
  • Premium Member
  • Premium Member
24 Oct 2020 00:17 #1 by Pylonuk
Glass cloth covering was created by Pylonuk
I posted this over on the RCM&E forum today, the info was well received so I thought I would post it here.
Pro’s Con’s
Stronger. Takes longer to apply than film.
Longer lasting. Maybe heavier if not applied well.
If applied well gives a better finish. More expensive.
Can be painted to a high standard. Needs more tools to apply well.
Glass cloth covering if carried out well gives a very tough and superior finish, the glass add’s strength to fragile trailing edges and tip sections.
The application of glass cloth and epoxy resin definitely takes longer than a heat shrink film covering, the cost is higher as well.
The glass once applied and cured can be painted to a high standard, at least to the standard of a new car finish.
Glass cloth and epoxy can be applied to many surfaces but is particularly suitable for wings covered in veneer or any balsa structure that is a closed surface.
Applying glass cloth and epoxy with out vacuum and mylar sheets is a multi stage process.
Application
Surfaces should be sanded smooth and all joints need to have a flush finish, a final sanding with 240 wet and dry paper used dry seems to be a good compromise between finishing speed and surface smoothness.
Excess dust should be removed from the surface by vacuum cleaner, air line or brush.
Cut glass cloth at about 30mm over size of the wing being covered and about 20mm for tail feathers. Don’t try and cover the whole underside of a wing in piece of material, rather split the material at the wing centre section and allow an overlap possibly on the centre section bandage.
For ease of covering only attempt to cover one side of the wing at a time, best to start with the underside first.
Mix epoxy according to the manufacturers instructions, for the Bob Smith and Zap products this a 1:1 mix ratio, I only use a brush, some advise has suggested using a credit card to spread out the epoxy into a thin film, my worry with this is that the balsa skins and tips can easily be bruised with the hard edge of the card.
Spread out the mixed epoxy to make a surface that is only just tacky, too little epoxy is better than too much at this stage, now take the pre cut glass cloth and allowing it to drape vertically lay it onto the tacky surface, start the drop from the centre section and work towards the tip. Immediately the cloth will start to soak up resin, it will also have very loose wrinkles, tease the wrinkles out from the edge, don’t try and force the wrinkles down with a brush or card at this stage.
Any areas that are dry can now have extra resin applied, the cloth goes transluciant when the correct amount of resin is present, equally any areas that look glossy wet should have the excess resin removed, with with a dryish brush or in bad cases with a kitchen towel dabbed onto the wet surface.
Allow the epoxy to cure, this will usually be over night at room temperature. Now carefully trim the excess glass off around the leading edge, tips and trailing edge. Initially a scalpel is good for this followed by gentle use of 240 grit paper on a small hard block.
Now repeat the process for the other side of the wing (most likely the top).
Now the wing or tailplane has been covered on both sides with glass cloth, we need to sand the surface with 240 grit wet and dry paper used dry, again a small hard block is useful for holding the paper on, the paper might clog up easily, this usually a sign that the resin is under cured.
Once the surface is sanded and de-nibbed then a second coat of resin is applied, again really spread the resin out and work it into the texture of the glass cloth, the surface will take on quite a shiny appearance on this second application of resin.
Allow the second resin application to cure, a decent temperature really helps at this stage. If everything has gone well you should be presented with a pretty decent surface which can be flatted back through successive finer grades of wet and dry paper used dry and then polished polished, or alternatively go on to priming and paint stages.
Materials required and where to get them.
Zap epoxy finishing resin – most model shops and online.
BSI finishing resin – Zen Racing and some model shops.
25 and 49 gram glass cloth – East Coast Fibreglass Supplies
1/2” resin brushes – Easy composites
Acetone – Many Ebay suppliers
240 wet and dry paper – Hardware shops
Kitchen towel
Mixing sticks and small pill cups – Many Ebay suppliers.
Scales 0-100 grams - Ebay
Thanks: Klipkopwildlife, Flytilbroke, Quorneng, THE BLACKBIRD, Ralpharr2001, paul d, crash happy
24 Oct 2020 09:01 #2 by Klipkopwildlife
Replied by Klipkopwildlife on topic Glass cloth covering
Very interesting, thank you, I've always steered away from glass cloth believing it to be very heavy, I've been itching to build a Curare for a while now, I might just try it.
  • Pylonuk
  • Premium Member
  • Premium Member
24 Oct 2020 09:29 #3 by Pylonuk
Replied by Pylonuk on topic Glass cloth covering
Klipkop
The Curare is a lovely plane and they do benefit from being light, especially in the outboard wing panels.
Is your from the MK kit or RCM@E plan?
Think about your colour scheme and I will give you some tips on getting it built nice and light from the finishing perspective.
B.
24 Oct 2020 11:13 #4 by Klipkopwildlife
Instant panic! Mary is in the process of moving me and my work space and doesn't remember where she put all the plans! Women, can't live with them, can't live without them! I must have 20 or 30 plans that I've bought over the years.
It must be the RCM&E plan which features the anhedral tail feathers. I've got a Nib OS60 pump with a pipe to go in it.
  • Pylonuk
  • Premium Member
  • Premium Member
24 Oct 2020 13:25 #5 by Pylonuk
Klipkop
The defining feature of the Curare was the anheadral tailplane, before that model Hanno had a design called the Super Siccory, that had a flat tailplane.
Give me a few hours and I will come up with some text on painting.
Regards
Barrie
24 Oct 2020 14:28 #6 by Klipkopwildlife
Hi Barrie, after a short domestic dispute I now have the plans that came from Nexus plans service. There's no rush on this since I a:- have no work space at the moment and b:- I am still suffering from Shingles which even after 7 months is showing no signs of going away any time soon! My ability to concentrate is shot and I even find it difficult to sit at the computer for more than 5 minutes at a time.
  • Pylonuk
  • Premium Member
  • Premium Member
25 Oct 2020 09:02 - 25 Oct 2020 09:06 #7 by Pylonuk
Paul
My thoughts are the other place is a collecting ground for ill informed people !! Actually I think it is something to do with My Time Media forums as there is a review of a Chinky digital micrometer by someone who should not be reviewing micrometers in anyway !!
The problem with thinning epoxy with something like meths, methanol or acetone is that you can/will get some of the solvent trapped in the epoxy, as not all of it will get to the surface and evaporate.
The trapped solvent does nothing for the properties of the epoxy !!
The technique you describe was documented in Aeromodeller magazine back in the 1970's, I think by Dave Clarkson. There are much better ways now.
If you were pushed into a corner and had to use araldite then a better way to reduce viscosity is to mix the epoxy in a shallow tin and float that tin in some hot water, this will dramatically reduce the viscosity and also kick start the cure reaction.
Curing epoxy or polyester resins in such thin layers is quite an ask of the material and you do have to 'line the ducks up to get a good shot' so foreign chemicals added don't help and neither does low temperatures.
Even when you see pigments added to epoxy resin, they do not form part of the reaction chain, rather they sit suspended with the cured materials around them at a microscopic level.
Barrie
Last edit: 25 Oct 2020 09:06 by Pylonuk.
Thanks: Klipkopwildlife, paul d, crash happy
25 Oct 2020 09:24 #8 by paul d
Replied by paul d on topic Glass cloth covering
Thanks Barrie, I must admit I thought it a strange idea, I will use some proper laminating epoxy.
  • Pylonuk
  • Premium Member
  • Premium Member
25 Oct 2020 09:39 #9 by Pylonuk
Paul
The Zap finishing epoxy is good, are you just sealing and coating with no glass cloth, something like an engine bay and cowl cheeks?
B.
25 Oct 2020 09:47 #10 by paul d
Yes Barrie, its on my slicker, I'll never get tissue etc round all the compound curves! It's going to be finished in traditional keil Kraft colours of orange black and white, the front needs to be black so I'll epoxy it and finish with gloss black humbrol ( a few people dispute the fuel proof qualitys of Humbrol but I've never had a problem getting it soaked in diesel).
25 Oct 2020 10:00 #11 by supertigrefan
Replied by supertigrefan on topic Glass cloth covering
Barrie,
You have PM :whistle:
  • crash happy's Avatar
25 Oct 2020 11:17 #12 by crash happy
Replied by crash happy on topic Glass cloth covering
Barrie. I have used 5% Styrene to thin polyester resins a few times. I don't know if can be used on epoxy ?
  • Pylonuk
  • Premium Member
  • Premium Member
25 Oct 2020 11:25 #13 by Pylonuk
Crash Happy
Styrene is lets say an approved dilutant for polyester resins, it is part of the make up of those resins.
Don't use it with epoxy as I doubt it would evaporate before the epoxy was cured and be worse than meths.
A good way if you are struggling with viscosity when applying is to gently blow a heat gun on the surface/epoxy as you are brushing it out, you get an instant viscosity reduction, no foreign materials mixed with the epoxy and a kick start to the cure reaction.
Regards
Barrie
  • Pylonuk
  • Premium Member
  • Premium Member
25 Oct 2020 11:27 #14 by Pylonuk
Paul
As I remember it Humbrol enamel is fuel proof to diesel but not glow.
Nice looking build by the way.
B.
25 Oct 2020 17:50 #15 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Glass cloth covering
I used to warm the resin before mixing, makes a huge difference to applying it
Time to create page: 0.227 seconds
