- Thank you received: 1203
Max Thrust Riot.
- crash happy
The horizontal stab was an easy repair, cut out the damaged bit & inset a new piece.
The wing, bearing in mind it had already been repaired once, was a bit more fiddly. The breaks were mostly at the join of the two halves & around the plastic retaining plates, one of which had snapped in half. After pouring hot water over the areas that had been compressed to get the shape back these were glued back together with epoxy. The retaining plate was glued & covered with glass fibre tissue for some added strength. The original spar was a solid aluminium rod inserted into aluminium tubes, that was bent & a bitch to get out because for some reason it had been glued in ! It eventually came out, tubes & all but un-salvageable. Two new 10mm tubes were cut & glued in & a carbon fibre spar (not glued) inserted before the two halves were glued back together. Next was to cut out a piece of the wing leading edge ( probably damaged when it clipped the hedge) insert a new piece & cover it with some self adhesive carbon fibre I had left over to tidy it up. In an effort to calm it down a bit we have been experimenting with different prop sizes. For reference the battery packs it came with are 3s 35c 3600 mah. The original prop was 12 X 6 draws 54 amps at wot & is producing 560 watts. The model weighs 3.67 lbs, so that equals 152 watts per lb.
Any advice ?
- Thank you received: 14307
Use the power to take off, then throttle back, just like full-size!
Fly at around half throttle, until it trains you on how to keep up with it!
With decent height, find out just how slowly it will safely fly. You will be surprised!
If you had been flying with a 4S, I'd have suggested you drop a cell, but I doubt the radio - via the speedo - will be reliable on a 2S, so that won't work.
It really comes down to what type of flying you are looking for.
A 3.67 lbs it is never going to be a 'floater' so it will come down to a trade off between low speed 'pull' (or attitude recovery!) against fast flying along with time to build up speed unless of course you aim for both states using 'absolute' power.
If you want to do any sort of aerobatics low(ish) down then slower speeds and 'pull' are good attributes using a bigger diameter finer pitch prop. For big 'sky writing' manoeuvres then maintaining momentum is key where thrust at speed is important from a prop with a smaller diameter & coarser pitch. You have to remember that with brushless the power falls away very rapidly beyond peak power rpm, almost like an IC with a tuned pipe, so the flying speed for maximum thrust is very pitch dependent.
Although I favour light weight the difference in flying style between my big wing area prop planes and the scale EDFs is dramatic.
I can't say I have a preference but if I fly them one after the other in ideal conditions I tend to prefer whatever I made the last flight with!
- crash happy
All of my other models have motors between 850 & 950kva, so the higher RPM is a bit new to me.
Putting a smaller one on will still have the motor revving at it's designed rpm's, but won't produce as much draft! (it cannot spin any faster!)
- crash happy
Quite, A fact of which I am very much aware. The recommended 9 X 9 prop is drawing 44 amps at WOT, & producing 460 watts of power. According to my test results a 10 X 6 is drawing 40 amps & producing 440 watts. Would this not indicate that the larger prop with a finer pitch is still reaching the motors max RPM ?Eric wrote: Don't forget - putting a bigger prop on will make the motor pull more amps, as it tries to reach it's designed rpm's. (less flight time!)
I have calculated the approximate flight times on 3s leaving a 20% reserve. A 2200 drawing a constant 15 amps = about 7 minuets. A 3600 at a constant 20 amps = about 9 minuets. Although only a guideline it should be a good starting point. The question now is, do I go for the 10X5 which gives me 91.3 w/p & a longer flight time or 10X6 giving 120 w/p but shorter flight time. To answer my own question, I think it would be prudent to have the extra power in reserve. Any thoughts ?
The square prop (9 x 9) is probably stalling, so isn't giving a meaningful reading. A square prop is what you would expect to find on a pylon racer, where the faster it goes, the faster it CAN go! (not counting airframe drag)
The 10 x 6, although an inch more in diameter, has 3 inches less pitch, so won't load up the same, and in an I/c model, that would be swung by a 2 st 40 glow.
A problem I had for a while was, because these leccy jobs tend to leap into the air very quickly I tended to ignore the fact that my ground control was lacking, because it didn't really matter! It does, of course because it makes you a better pilot! With really excessive power you need the ground control because you now have other forces to contend with, Torque roll, Gyroscopic precession and recession to name but a few. Another thing, have you thought about using a curve on the throttle channel like the Helicopter boys do? Even Expo might help.
Don't forget the Watts/lb is not the complete solution.
The pitch of the prop will determine at what airspeed that power has an effect.
You are measuring the Watts 'static' at no forward speed. The 9 x 9 is likely just 'absorbing' a proportion of the Watts and developing less thrust compared to the 10 x 6, however as the plane speeds up the 9 x 9 will start to work properly and generate possibly more thrust with very little rise in the revs.
The 10 x 6 on the other hand will more rapidly speed up as the air speed rises producing less thrust (and drawing less amps) the nearer the rpm approaches the motor's no load speed.
Without some telemetry (rpm, Amps and airspeed) it is very hard to say what prop is making the best use of the Watts used.
It really comes down to "suck it and see" to find out what suits you best.
- crash happy
- crash happy
I presume the original design must have used a seriously very heavy motor.
- crash happy
I certainly don't think it helped, its a completely different model now.Klipkopwildlife wrote: Crash said, "The new fuz came with a steel ballast block mounted just behind the motor cowl." I wonder if it's removal caused the CoG to be too far back even with the heavier motor and batteries. This could be the reason for its refusal to fly nicely.
Quorneng. Just the opposite, I think. The original has a ST3511 850kv, weight unknown. The replacement is a Rimfire EF1 Race 35-45-1250kV, weight 7.2 ounces. I presume the block was added in the original due to the fairly short motor & nose. The tail is is quite chunky too, so there is a bit of weight in it. The guy said he took the block out to compensate for the longer motor & larger batteries. All I know is it balances & fly's really well now. If it ain't broke, why fix it!
