Seagull Challenger
  • The Beard
07 Aug 2015 22:35 - 06 Sep 2015 08:37 #1 by The Beard
Seagull Challenger was created by The Beard
I built one of these at Christmas only flew it last week it crashed seriously on its Maiden .Either a duff battery or switch not sure but just dropped vertically no re[sponse to controls and no life when we reached it Im building a new one
Last edit: 06 Sep 2015 08:37 by .
  • The Beard
08 Aug 2015 22:22 #2 by The Beard
Replied by The Beard on topic Seagull Challenger
this model has gone together very well no problems should finish it over the weekend and very enjouyable using new 2300 battery and new switch.Just need to fit the wings and set up ailerons
  • The Beard
17 Aug 2015 20:34 #3 by The Beard
this lovely model has gone to the field twice but due to massive activities havent been able to fly
  • The Beard
28 Aug 2015 05:26 - 06 Sep 2015 08:39 #4 by The Beard
finally maidened the Challenger and the under carrage comes assembled Although tight on take off soon one of the pants fell off followed by a wheel.I landed gently in th long stuff but the mount tore out but nothing seems to hold it in .It went to the field wednesday but far to windy.I fitted the wrong engine Its a newish sc 52 2 stroke but cuts out as you power up so may change it
Last edit: 06 Sep 2015 08:39 by .
  • The Beard
29 Aug 2015 01:40 #5 by The Beard
im working all weekend so hoping for after work Sunday
  • The Beard
30 Aug 2015 08:51 #6 by The Beard
its a lovely day here so hoping I can get a flight in after work I finish at 4 on a Sunday
  • The Beard
31 Aug 2015 09:17 - 06 Sep 2015 08:40 #7 by The Beard
couldnt fly the challenger too many caravaners and dog walkers and wind its an airfield for goodness sake
Last edit: 06 Sep 2015 08:40 by .
  • The Beard
06 Sep 2015 08:01 #8 by The Beard
you know when a model has caused you a few problems but you wont give up well on Wednesday I tried again ,Thw wind was down and noone around. so after flying the acrowot and junior 60 which flew until it ran out of fuel and glided around perfectly landing on the strip ,I was ready to challenge the Challenger once more .2 fantastic flights later and I was so pleased.Lands superbly a real treat and tends to take off hard right so still some trimming to do but very happy
  • The Beard
06 Sep 2015 08:03 #9 by The Beard
im changing the engine as it still stalls as you power up to take off
  • The Beard
06 Sep 2015 08:04 #10 by The Beard
this particular engine has always done this its newish and when you get passed the stall its fantastic and great in the air
  • The Beard
06 Sep 2015 08:05 #11 by The Beard
its an SC 52 two stroke my favorite engine
06 Sep 2015 11:03 #12 by old fart
Replied by old fart on topic Seagull Challenger
The Beard wrote: im changing the engine as it still stalls as you power up to take off
Sounds like it's running a tad lean.
06 Sep 2015 11:19 #13 by one tenor
Replied by one tenor on topic Seagull Challenger
Re your engine Check ALL the "O" ringsin the carb and all channels and bores are clear. Occasionally some assembly oils can harden round the rings and in bores and channels. . check everything IT DOESN'T TAKE MUCH to upset the transition from idle to full throttle.. Full size carbs use an internal pump to overcome this..Also make sure there are no burrs any where
  • The Beard
09 Sep 2015 06:25 #14 by The Beard
your right there is something wrong but once passed this stall point its perfect Ive tried richening it but to no avail but Ive now changed it as I have plenty of engines.I wont give up ill change the carb next time.
  • The Beard
24 Sep 2015 22:35 #15 by The Beard
With the engine changed its transformed the model easier to take off and seems better trimmed I model really lands well
Time to create page: 0.215 seconds
