1/20 EDF Buccaneer
- Monz
I'm off to the South Coast for a few days for work so taking a little 'down time' travel box along to occupy me in the hotels. I'll stop at the local Hobbycraft and buy an A4 cutting mat to go in the box in the morning.
- Nigel
- Thank you received: 405
- Monz
Derek's fans have ample power, provided you build suitably...
- Squirrelnet
- Thank you received: 2067
it will be a pleasure to watch the build progress.
A FF EDF sounds a particularly brave (or is that terrifying?) option given the weight/speed that is likely to result from the relatively small wing area of the Buccaneer.
I know you wont have the power on for very long but even my 32" span, 200 g EDF Venom goes a surprisingly long way pretty quickly and if I have done the sums right your 1/20 Buccaneer will only have a span of 26.4" for its 300 g.
As always I shall be following with great interest.
Quorneng wrote: Monz
It looks to me that you've been too long away from Free Flight Q. Monz has picked a good size, weight and power source for the model. It should fly well!
The secret is in the building, finishing, trimming and operating of the model in the 'right' environment. Modern flight profilers also help in that the motor power, length of run and rundown characteristics can be programmed predictably.
I'm sure it'll all come clear as the build progresses
I don't doubt it will fly.
My concern was simply its likely speed in an FF situation.
- Nigel
Just had a quick browse on the net for these fans - Chris Golds (is he still with us?) did a 29.5" Sea Vixen with two 32mm DK fans, but he did power them with Feigao brushless motors on 3S LiPo's. AUW was 20oz, so the fans are up to the job!Monz wrote: Hi Nigel, first FF edf for me this. I'm using two of Derek's 32mm fans. I've seen one of them power a 257g Hunter comfortably so I reckon two of these will be ample for the weight I'm aiming for - 300 - 350g - or thereabouts
The Sea Vixen wing loading was 11oz/ft2 - from yours and Quorn's useful numbers I reckon you're heading for between 11 and 13 oz/ft2 (33 - 39 g/dm2). Any idea if Derek used a brushed or brushless motor? Brushed is kind of old-tech for R/C models where I usually play, apart from ultra-lights such as the Vapor (<1oz /30g). I see that HK do a 'Basher' series of brushed 1S 4Amp (~12 Watt) motors for mini-4WD car things that are available in up to 10000kV. 12Watts vs 300-350g model is outside my experience but I will cogitate.
Just being curious - I'm with Quorn, trying to tally your plans with my experience zone. If I can help, I surely will.
Good luck, Nigel
- Nigel
Thanks, Quorn, that's a useful benchmark. I think we're maybe coming from the other end of the spectrum where RC EDF are finally enjoying an excess of power. Derek's model at last year's FF Nats certainly appeared to only have just enough power, but he is equally certainly a master of the art.
regards
Nigel
- Monz
Here are two videos of models using the 32mm fan. Ron is using only a third to half power in these flights. I think Derek also doesn't turn them right up till his models are properly trimmed. So they have lots of grunt.
www.facebook.com/monz.lyons.16/videos/vb...2117/?type=3&theater
Q, your Venom has a much larger fan in it? And being RC the flight profile is very different from FF. The Bucc is going to be quick, but I'm confident it will be very near to scale speed once trimmed.
I made a start on the first fuselage half, some pics to follow later after some more progress.
600 kts at sea-level?
It has a 40 mm cheap AEO which is reasonably light at 18g and low powered which is why I made the comparison with the 2x32 mm that you are going to use.
I was actually more concerned at the wing loading. You are predicting 50% heavier and it will have less wing area. It must fly faster than my Venom.
- Monz
