Mamselle by Vic Smead
  • The Beard
28 Sep 2012 16:10 - 28 Sep 2012 16:32 #1 by The Beard
Mamselle by Vic Smead was created by The Beard
Ive had Mamselle for a couple of years ,she tried to elope with a lost Eagle but I found her.She tried to commit suicide by throwing herslf in a pond but just floated on top.and a wlker helped me retrieve her.Havent flown her since.The story is this.Ive lost a hose for my cleaning machine.In moving stuff around I put my hands on Mamselle.As is my lust I turned the prop,funny,no compression,nothing.Well blow the cleaning and the hose.must look see.Downstairs in the lounge and remove the engine.take the back plate off and there is the problem.\the gudgeon pin has snapped in half and is laying there.Took the head off.Piston is smooth in the liner,no marks its all perfect,so how has this happened.Is this what happens when a model gets a broken heart,I will soon have her mended.
Last edit: 28 Sep 2012 16:32 by The Beard.
  • The Beard
28 Sep 2012 17:24 #2 by The Beard
Replied by The Beard on topic Re: Mamselle by Vic Smead
Not as easy a fix as I hoped.I had another defunct thunder tiger engine not a 15 bt a 35 and the gudgeon pil is much bigger ,possibly drill the piston,just waiting a call back
  • The Beard
28 Sep 2012 17:53 #3 by The Beard
Sussex Models think they can supply one,its all a bit strange as Im convinced its broken when not running.
28 Sep 2012 19:08 #4 by Quorneng
Replied by Quorneng on topic Re: Mamselle by Vic Smead
Was it running when it tried to be a float plane?
The prop would stop very quickly in contact with water.
Maybe in your concern about a soggy airframe you did not actually turn the engine over before putting it away. ;)
I would have to agree shearing a gudgeon pin is unusual, normally the con rod bends before that happens, maybe it was already cracked.
What does the break look like? A fatigue crack leaves a distinctive pattern.
  • The Beard
28 Sep 2012 20:10 #5 by The Beard
No the engine had stopped and didnt get wet.Its beautifully clean inside not a mark anywhere
28 Sep 2012 20:34 #6 by Eric
Replied by Eric on topic Re: Mamselle by Vic Smead
Gudgeon pin - in the piston, connected to the con-rod, or the crank pin, on the crankshaft, and connected to the con-rod?
If it is the crank-pin, they were often just pressed into a drill-hole opposite the balance weight on the shaft.
  • The Beard
28 Sep 2012 20:39 #7 by The Beard
The gudgeon pin connecting the piston to the con rod.I cant figure it out,the pin was laying by the side of the conrod,how did it fall out,must have been pulled from the centre of the piston but there isnt a mark on anything else
28 Sep 2012 21:07 #8 by old fart
Replied by old fart on topic Re: Mamselle by Vic Smead
Maybe that is why it stopped in the first place. :unsure:
28 Sep 2012 22:47 #9 by Eric
The gudgeon pin cannot possibly fall out! It is the full width of the piston, less a softer bush on either side, so that it cannot score the liner!
For it to be pulled out (most unlikely) it would have had to pull the piston casting to bits, so there would be some bits of metal in the crankcase as well.
I'm stumped with that one!
  • The Beard
28 Sep 2012 23:59 #10 by The Beard
THe model ran out of fuel and landed itself ,the engine was fine then.Its been tucked away since.It is in perfect condition apart from the gudgeon pin snapped in half in the middle,its a mystery.There are no small plastic end pieces,like on the engine I stripped .I stripped a 25 hoping the pins would be the same but its a fair bit larger.
  • The Beard
29 Sep 2012 00:02 #11 by The Beard
Now your wondering why it landed itself.It was hand launched by a collegue who switched it off has he let it go.Thats was why the take off was perfect,I wasnt in control.We watched it go up and up in circles until the engine ran out of fuel .I then followed it as the wind took it away.
29 Sep 2012 00:04 #12 by Eric
Snapped in half - silly me, I should have read the first post again :oops: You will need a new piston as well, because it's a fair bet the centreing tube under the head will have been distorted or cracked.
  • The Beard
29 Sep 2012 01:12 #13 by The Beard
Ive inspected everything carefully now and I think it must have happened in the air.The most obvious sign is the conrod ,the hole is oblong and worn with a shoulder.The piston looks fine but I think I need an engine.
29 Sep 2012 01:57 #14 by Eric
Does the piston move?
Perhaps it seized at tdc, and the stress sheared the pin?
  • The Beard
29 Sep 2012 03:10 #15 by The Beard
No the piston pushed out easily ,and as I say the only visible mark is on the conrod where the gudgeon pin hole is oval and has s burred edge.
Time to create page: 0.288 seconds
