- Thank you received: 2182
Rebuilding a crashed ARF Bird of Time
- Grumpy42
A mate of mine who was silly enough to be seduced by that bloody *lectric crowd had his (choke, gasp ( forgive me Lord Nitro) electric power assisted Bird of Time up to around 200 feet when the stabiliser servo - (a metal geared one) decided to go on holidays. The result made every one at the field cringe. Being an old fool who is known to embrace lost causes (NO GASSER - NITRO IS NOT A LOST CAUSE
Being a properly anointed Knight of the Nitro Brigade I immediately gave all that distasteful electric stuff back to the owner - not that it was much use - even the you beaut folding prop had to be dug out of the turf and took the bits home to contemplate a proper burial - errrrr I mean rebuild. As the Bird of Time is one of my all time favourite models I decided to restore it to it's proper pure glider configuration. The following photos are a little hard to look at if you are an aeromodelling enthusiast - rather like looking at gruesome forensic photos of maimed bodies. But I WILL win the bet and rebuild it - as it is a pure glider even those darkside zombies might be able to look at the rebuild - I won't mention the power pod with a 40 2 stroke till the very last moment
Attachment not found
The sad remains
Port outer wing panel
Port inner wing panel
Starboard inner wing panel
BIG crack in the FRP fuselage - it's nearly 8" long
Even the all flying stabiliser got damaged
This is where the offending servo lived
Now before any sharp eyed observer tells me I KNOW the two inner wing panels are the wrong way around -all the same comments or thoughts or suggestions are welcome. NO Tony and Gasser - fitting an electric motor is not a good thought or suggestion.
though it looks fixable, it will be a long job.
shame about the electric though, think how quiet it would be with it.
- Sarah-Jane Smith
- Gone
- Grumpy42
Point two - Willow - I will forgive your frivolous remark because of your undoubted tender young years however if you persist you will be strapped to a chair and made to watch endless repeats of control line team racing.
Ahhhhh How did the two words, brave and nitro come in one sentence?? I am weakening where is my Tutu
- Grumpy42
The Beard wrote: It started as a box of bits so now it needs a bit od TLC and itll be a beauty.I have a glider,I have a cute new SC15A, what you think Grumps could I would I what fuel tank.
Don't know the SC15A Stephen but if it's your normal 15 size RC motor and not a piped screamer of some kind then a 4 or 6 oz tank will be enough depending on the model and what you want to do with it. I'd use a 4 oz tank if the thing was mounted on a pylon to tow a medium sized glider up. Then again - for a B of T sized model I'd stick a 40 on the pylon!!! It all depends on the weight of the thing.
- Grumpy42
The Beard wrote: Youve seen a photo of it,its the one with the blue head.I dont want a pylon I want it in the front,so it goes up and glides back,loke what gliders do,oh dear,have to be electric then.
Two questions then Stephen - what wing span and what weight is the glider? If it's under about 6 foot and doesn't weigh more than a couple of pounds then a 15 with a 4 oz tank will take it up there - if you want to regain high a few times and keep it up there for an extended time then a 6 oz tank might be the go. The Bird of Time I'm rebuilding is ARF and has a heavy FRP fuselage - the whole model is very heavy for it's size - that's why IF I was going to fit an engine it would be on a pylon and around 40 size to get the thing up there in a fast climb. I'd only fit a tank small enough for just the the initial climb.
Are you really planning on spoiling the glide ratio of that beautiful airframe with a fixed prop?
A folding prop on IC would be an interesting. Has it been done?
- Grumpy42
Quorneng wrote: Grumpy42
Yes Quorneng I believe some one has done it but I have NO intention of rebuilding it as any thing more than a pure glider -powered only by the wind. As much as I am an IC engine man there are some things I just will not do.
- Grumpy42
Port outer panel - the worst of the two - I'd normally scrap it but just to prove it can be done I'm going to rebuild it!
Join between port inner and outer panels.
The Starboard inner is worse
- Sarah-Jane Smith
- Gone
If anyone can rebuild it you can (I have gaffa tape on stand by hehe
Nevertheless very rewarding (and a relief) when the structure starts to return to its original form.
Look forward to following its progress.
