stearman pt17 restoration
26 Aug 2014 20:16 #1 by Ex-Member
stearman pt17 restoration was created by Ex-Member
I picked this model up from Alan at the nats and plan to do a restoration on the aircraft at a later date.
It has been very nicely made and just needs some tlc and a few scale details added.
but i have a shed to sort and a tsr2, auster, shackleton, hurricane to finish first.
06 Jan 2015 19:52 #2 by Ex-Member
Replied by Ex-Member on topic stearman pt17 restoration
well i dug this out of the pile in the corner of the shed and dusted it off.
i have cut the ic motor mount off and cleaned up the front.
cut a hole in the front cockpit floor so i can fit a flight battery.
putting some rivets on the sheet metal area's of the fuselage and will re paint it later this week.
need to order an electric motor for it next and then make a dummy radial engine to hide it inside.
then some rib tapes on the wings and a re paint to us navy colours.
be another finished model that i can fly soon i hope. :cheer:
  • alan cantwell
  • alan cantwell's Avatar
  • Inactivated User
  • Inactivated User
06 Jan 2015 20:24 - 08 Jan 2015 16:06 #3 by alan cantwell
Replied by alan cantwell on topic stearman pt17 restoration
Word of warning, these models were notorious for needing a church roof on the front end, make the dummy engine heavy,
Last edit: 08 Jan 2015 16:06 by .
06 Jan 2015 21:36 #4 by Quorneng
Replied by Quorneng on topic stearman pt17 restoration
As an electric conversion I would hope Tony can avoid the need for much lead with suitable battery placement. ;)
06 Jan 2015 21:50 #5 by Ex-Member
i am thinking 5 or 6s tucked right in the nose behind the firewall.
need to weigh the thing next to work out what size motor/esc and battery next.
07 Jan 2015 16:46 #6 by Ex-Member
thought i would play with some rib tapes.
not brilliant, but not too shabby.
need to do the underside of the top wing next and then the lower wing needs looking at.
  • alan cantwell
  • Inactivated User
  • Inactivated User
07 Jan 2015 17:55 - 08 Jan 2015 16:10 #7 by alan cantwell
On mine, i had two sheets of lead bolted to the front bulkhead, and a 91 surpass, an on board D cell battery, for the on board glow, and a 4 cell sub c size flight battery, where secured right behind the bulkhead, i also strengthened the bulkhead with a piece of half inch oak, Shaped round at the leading edge, Getting the picture?
Last edit: 08 Jan 2015 16:10 by .
08 Jan 2015 15:52 #8 by Ex-Member
well this thing weighs 7.5lb so far without motor/esc or battery.
i am expecting 11lb when it is finished.
rib tapes still going on and some paint slopped on.
will repaint the yellow on the wings and the markings later.
needs a grey fuselage and a light blue tail as well.
the rigging wires will be fun.
09 Jan 2015 18:09 #9 by Ex-Member
undercoat has gone onto the fuselage.
more rib tapes on the lower wing
and i have started painting the markings on the upper wing.
hope to finish painting the fuselage and finish the rib tapes tomorrow, fingers crossed.
  • alan cantwell
  • Inactivated User
  • Inactivated User
09 Jan 2015 19:24 #10 by alan cantwell
Personally, call me old fashioned, i would have put gear in it, and just flown the thing,
09 Jan 2015 19:28 #11 by Ex-Member
i like to make models "mine" by changing things Alan.
  • alan cantwell
  • Inactivated User
  • Inactivated User
09 Jan 2015 21:18 #12 by alan cantwell
Your plane Tony, it was looking old, Needed a repaint, but dont ever try to strip it off, that coverings doped nylon
09 Jan 2015 21:40 #13 by Ex-Member
hope to make it look a bit like this.
  • alan cantwell
  • Inactivated User
  • Inactivated User
09 Jan 2015 22:24 #14 by alan cantwell
Beat ya, This is in my attic
www.greatplanes.com/discontinued/gpma1349.html
09 Jan 2015 22:34 #15 by Ex-Member
humpf
well i will burn it now then.
Time to create page: 0.192 seconds
