FMS P51 Mustang
  • The Beard
09 Mar 2016 09:16 #1 by The Beard
FMS P51 Mustang was created by The Beard
Mine arrived yesterday and incredible value for money from Kings Lynn Models .Ive bought the Siver Red Tail model already has decals and not a lot to do .Instructions as with any chinese model are vague but did come with receiver and controller which I wont use.One question ive never thought about.It has a warning not to use higher than 6 volts to servos etc but recommends 14.8 bvolt battery.I assume the speed controller sorts that out but ive never thought about it before.
09 Mar 2016 09:47 #2 by Eric
Replied by Eric on topic FMS P51 Mustang
That's what the BEC (Battery Elimination Circuit) does, Beardy.
It splits the volts from the lipo, so the speed controller gets the full load, and the receiver gets about 5v which also works the servos. [badass]
  • The Beard
09 Mar 2016 12:00 #3 by The Beard
Replied by The Beard on topic FMS P51 Mustang
thanks very much Eric
  • The Beard
09 Mar 2016 15:32 #4 by The Beard
after a short time flying I was able to give the P51 some attention.Very thoughtful packaging,example the screws are labelled and the horns ands screws are cellotaped to where the should go be it elevator or rudder.
First job is the propellor .the blades screwing onto the back of the spinner each one held by 2 screws.a big 4 blade prop
  • The Beard
09 Mar 2016 15:34 #5 by The Beard
Next was fitting the horizontal stabiliser and rudder all easy stuff,and followed by the horns
  • The Beard
09 Mar 2016 15:34 #6 by The Beard
ive taken photos but nothing is connecting to my computer
  • The Beard
09 Mar 2016 19:50 #7 by The Beard
ive selected a receiver no spare room on my computer
  • The Beard
11 Mar 2016 10:35 #8 by The Beard
I meant controller ,The only problem that's come up is the plug for the Battery as no one seems to have them
11 Mar 2016 11:17 #9 by Eric
What kind of plug - someone may have one in their junk box. :unsure:
  • The Beard
11 Mar 2016 13:44 #10 by The Beard
I would photo it but my phones refuse to connect to my computer.Ill just solder a deans on to it
  • The Beard
12 Mar 2016 14:06 #11 by The Beard
I hope to be soldering tonite had to feel around shed in the dark as I cannot find a torch for a ceramis tile to use as it looks a challenge to remove the speed controller and the lead is quite long so should be ok
  • The Beard
13 Mar 2016 06:46 #12 by The Beard
the soldering went brilliantly and was very successful.I then popped a battery in and everything works perfectly except for my controller .The right control has fallen in and I can see screws have fallen out but cannot locate them so careful searching tonite inside.Even the tail wheel is retract
  • The Beard
13 Mar 2016 10:05 #13 by The Beard
ive brought both my phones to work and both have downloaded onto my lap to my lap top so lets see what I have
  • The Beard
13 Mar 2016 10:06 #14 by The Beard
nice
Thanks: Klipkopwildlife, Septic
  • The Beard
13 Mar 2016 10:07 #15 by The Beard
Myself and my grandson
Time to create page: 0.288 seconds
