- Thank you received: 690
Enlarged VMC Se5a for Indoor R/C Flying Only
- Septic
Well I thought the Se would be a great design for Flying Only at the Indoor R/C Nats, so set about enlarging the plan to 22" and redesigning the wings to accomodate ailerons.
The wing construction was altered to allow the use of laminated upper wing ribs, and my simplified spar technique. Many thanks to Mr Sephton for the inspiration on that one!
The ailerons are operated by a single central servo in the fuselage, operating pull lines, running through full span micro PTFE tubing. The pull lines are invisible polyester thread. All four ailerons are hinged so that at rest the are fully deflected upwards. The lines are pulled to centre the surfaces, relaxe the pull they go up, pull harder they go down. Really simple. The top wing ailerons are simply tethered to the bottom wings ailerons. The servo has only ever to pull with enough strength to operate one side at a time.
Still have the Undercarriage to make, so far the model weighs 46g, so on target for under 50g, but it will be tight. The model spans 22"
Cheers
Danny
tap - tap.......rivet
I've been thinking about the ailerons. When the servo pulls one side down, the other side is pulling up and therefore, helping with the effort required. In fact, with equal pull on both sides, the net force on the servo should be zero....which makes it a very elegant solution for a simplified aileron control.
- Squirrelnet
- Thank you received: 2067
- Septic
Great minds think alike....
- Mike Rolls
- Thank you received: 573
No bias. It used a complete closed loop.
From the servo out in the lower wing round the lower RH aileron, up and round the upper RH aileron, right across the upper wing, back down around both LH ailerons and back to the servo.
To allow the line to be inserted after it was covered I used flexible drinking straws as cable guides.
It worked!
I can't get a Vimeo video to work but it can be found here vimeo.com/55798546
Built for out door flying, so a bit heavy for indoor, but even so much too delicate. It has only flown once on a flat calm day but was still damaged on landing!
It has hung on the wall for 3 years, maybe one day......
- Septic
Love your solution though
Cheers
Danny
- Septic
- Septic
Cheers
Danny
- Septic
- DHNut
- New Member
- Thank you received: 29
Ricky
- Septic
Cheers
Danny
- Squirrelnet
