TOPIC: Surrey flying services AL 1
Surrey flying services AL 1 25 Nov 2016 13:10 #1
  • Tony B
  • Tony B's Avatar
  • More Details
    • Thank you received:11983
thinking of doing a scale biplane in depron and tissue.
1/4 scale would only make it a wingspan of 84", so not huge but big enough to add some good scale detail.
hmmmmmmmmmmmmmmmmmmmmmmmmmmm
Andy you are naughty. :P
as René Descartes said. " i build therefor i am "
Last Edit: 25 Nov 2016 13:10 by Tony B.
The following user(s) said Thank You: Klipkopwildlife, boz, Firewood
Surrey flying services AL 1 25 Nov 2016 13:24 #2
  • Quorneng's Avatar
  • More Details
    • Thank you received:7925
depron and tissue
Just remember you cant use any form of acetate dope to tighten/seal the tissue.
Last Edit: 25 Nov 2016 13:24 by Quorneng.
The following user(s) said Thank You: Tony B, boz
Surrey flying services AL 1 25 Nov 2016 13:30 #3
  • Tony B
  • Tony B's Avatar
  • More Details
Thanks for the heads up Simon :)
Diluted ronseal floor varnish will work just as well.
i have used it before on open structures with no issues.
The following user(s) said Thank You: boz
Surrey flying services AL 1 26 Nov 2016 17:32 #4
  • Andy Sephton
  • Andy Sephton's Avatar
  • More Details
    • Thank you received:6186
Quorneng wrote:
depron and tissue
You can if you seal the Depron first - we've been using similar incompatible materials successfully in the FF world for some time. ;) ;)
Too much thrust is never enough!
Surrey flying services AL 1 06 Dec 2016 16:14 #5
  • Tony B
  • Tony B's Avatar
  • More Details
whilst waiting for paint on the Ensign to dry, i cut a few bits out.
going to be a big bugger me thinks. :P
The following user(s) said Thank You: Klipkopwildlife, Andy Sephton, Firewood
Surrey flying services AL 1 06 Dec 2016 20:49 #6
  • Tony B
  • Tony B's Avatar
  • More Details
i aim to cut the fuselage cores tomorrow and have an offer up for fixing.
can't glue anything yet until i have decided where all the bits will have to go, like servos and cable runs etc..
The following user(s) said Thank You: Firewood
Surrey flying services AL 1 06 Dec 2016 21:57 #7
  • Tony B
  • Tony B's Avatar
  • More Details
need a redesign of some of the formers already as i need to sort out the cabane structure.
so my thinking is to use a ply box made up from two formers braced with more ply stringers to handle the cabane and u/c mounts.
then glue the front and rear of the fuselage to this construction.
once the sheeting has been added and the outer stringers glued onto this, it should be strong enough for flying.
though only time will tell.
fun this biplane lark isn't it. :P
Last Edit: 06 Dec 2016 21:57 by Tony B.
The following user(s) said Thank You: Eric, Quorneng, Andy Sephton, Firewood
Surrey flying services AL 1 06 Dec 2016 23:34 #8
  • Eric
  • Eric's Avatar
  • More Details
    • Thank you received:5554
Someone put the missing 'R' into the title, please! :S
Surrey flying services AL 1 07 Dec 2016 07:34 #9
  • More Details
    • Thank you received:1761
ar's done. ;)
The following user(s) said Thank You: Garry Pollard
Surrey flying services AL 1 07 Dec 2016 11:57 #10
  • Eric
  • Eric's Avatar
  • More Details
Nope - still seeing - Surrey flying sevices AL.1 [badass]
Surrey flying services AL 1 07 Dec 2016 13:22 #11
  • More Details
F5?
Surrey flying services AL 1 07 Dec 2016 13:59 #12
  • Quorneng's Avatar
  • More Details
I must say I had not noticed - trust Eric to spot it!
The main title is now correct but the "Subject" heading (which appears on every post) still shows "sevices"
Surrey flying services AL 1 07 Dec 2016 14:29 #13
  • Garry Pollard's Avatar
  • More Details
    • Thank you received:2822
Haha, Sorted Wish the O/P could spell :woohoo: :evil: [badass]
Been flying for over 60 yrs and still love it
30 yr old mind driving a 81 yr old body an unequal struggle
Surrey flying services AL 1 07 Dec 2016 15:43 #14
  • Tony B
  • Tony B's Avatar
  • More Details
bogg off.
i kan spel i justs choozes not to, so i kan wined up Eroc.
:P :P
Surrey flying services AL 1 07 Dec 2016 15:48 #15
  • More Details
:woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
Time to create page: 0.206 seconds
Amount:
 GBP
