- Thank you received: 10842
Electric set up for multimotor model
Eric i dont know if it is worth buying anything for it as it is very heavy, i was new to the hobby again, never done fibre glassing before and i think i got to much on.
Ill see
I was going to fit the batteries from underneath in my ignorance, dont think it was a good idea now, a removable cockpit is the answer
I was going to use two esc's one for the outboard one for the inboard mine were 30A with the lipo's and esc's in the fuselarge
Its a nice build Dean i used the complete pack of wood from RCM&E
- Away
By the way, if your BECs are Linear (read the blurb that comes with the ESC) you do not need to remove the positive wires from the ESCs. If they are the other kind then you do, because they will fight and end up frying your RX and servos!
- Dean M
- Thank you received: 326
His reply was that it wasn't that much harder to build than any of his other designs and it would be better to build something I really liked that way there would be more chance of actually finishing it!!
I May try a different method of covering it to what I am used to (only used iron on coverings!!)
I have heard people talking about using brown paper and pva, A chap on RCM&E covered a hurricane with this method and the results were really good.
Dean
I nearly choked on my latte.
Dean, I've used tish and cellulose dope - a long time ago, and nylon and cellulose. I much prefer iron-on, it is so much easier once you master it. (and a lot less smelly!)
When you crash a 'tex model, you don't need a bin-bag, it is already bagged up for you! :S
- Dean M
I think I Will use solartex on my puppeteer so are the paints fuel proof or do they need treating?
- Dean M
Dean M wrote: Ha ha I was going to cover it then build it :lol: :lol: :lol:
I would test fly it first just to see if you like it.
- Dean M
would THESE motors be any good? they say 25A so would that be about 250 watts on a 3s?
Dean
