Extra 260
  • Dragonfly
28 Oct 2025 15:07 - 28 Oct 2025 15:09 #16 by Dragonfly
Replied by Dragonfly on topic Extra 260
I was also thinking the same as you BB about the ally box section cutting into the ply while the engine is running due to vibration. but didn't get chance to write anything down as the missus had just come back from shopping so had to go and help to bring the shopping in.
Last edit: 28 Oct 2025 15:09 by Dragonfly.
28 Oct 2025 16:46 #17 by Klipkopwildlife
Replied by Klipkopwildlife on topic Extra 260
A good thought Tony, perhaps some epoxy around the base to spread the load?
28 Oct 2025 20:16 #18 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Extra 260
I dont have many useful thoughts nowdays
31 Oct 2025 17:15 #19 by Klipkopwildlife
I haven't been too good of late but managed to glue a piece of Obeche across the mounting box.
More later
Thanks: Eric, Flytilbroke, Quorneng, THE BLACKBIRD
01 Nov 2025 12:00 #20 by THE BLACKBIRD
Is that going to be enough, i was thinking bigger going back halfway on the box
27 Nov 2025 11:24 #21 by Klipkopwildlife
I haven't had a lot of time recently, my sister's not very well, Pretoria is getting a lot of rain which brings on her Bronchitis.
I'm getting close to doing test runs on the engine.
and
I hope to do a video of the first start and run up
Thanks: Eric, Flytilbroke, Quorneng, THE BLACKBIRD, jon.in.swansea
03 Dec 2025 08:00 #22 by Klipkopwildlife
I managed to find some time to do a first start yesterday
I initially flooded it (difficult to do with an updraft carburetor), I then turned it by hand until I had a 'knock' from both cylinders.
Thanks: Eric, Flytilbroke, THE BLACKBIRD, jon.in.swansea
03 Dec 2025 08:08 - 04 Dec 2025 17:10 #23 by Klipkopwildlife
Then a run at full beans, a number of issues came to light!
Last edit: 04 Dec 2025 17:10 by Klipkopwildlife.
03 Dec 2025 08:14 #24 by Klipkopwildlife
She was tethered
An aileron fell off, obviously I didn't glue it very well
And the down pipes fell off
But that's why we do these run ups, isn't it?
Thanks: Quorneng, THE BLACKBIRD
03 Dec 2025 09:00 #25 by THE BLACKBIRD
The engine sounded nice and it responded to the needle tweaks,
It looked a bit dangerous with you stood there right in line with the prop, i know it was tethered but it was still moving around   be careful out there
I still have the scar to prove it
03 Dec 2025 09:30 #26 by Flytilbroke
Replied by Flytilbroke on topic Extra 260
That's a good start. Pun intended   I would strongly suggest you devise some means of properly tethering your model before you proceed with any further engine adjustment as you are very close getting yourself a likely major visit to Hospital. That is a nice engine you have there.
04 Dec 2025 07:11 #27 by Eric
Replied by Eric on topic Extra 260
Please, Tony - do NOT stand in line with the prop! If it decides to throw a blade, guess where it will go!
Your 'tether' needs to be lower, so the tail cannot rise.
You put the first start vid on twice!
Bits fell off - always best when this happens in testing, not in flight!!
04 Dec 2025 07:22 #28 by jon.in.swansea
Replied by jon.in.swansea on topic Extra 260
The scale of the 260 vs the load-bed suggests it should be visible from quite a distance.
How many seconds will it take to traverse the available flying field?
04 Dec 2025 17:12 #29 by Klipkopwildlife
Yes Jon, big, I haven't down an rpm check as yet, this motor is supposed to give 9,000rpm so the 15x6 will give me about 80kph.
Thanks: jon.in.swansea
05 Dec 2025 06:44 #30 by jon.in.swansea
Ah 80kph is equivalent to a rather bone-jarring drive on the Beauty Road (the seriously rutted gravel road connecting Tony to the outside world).  Any idea about how it might fly if you constrain the revs?  And what will the local raptor population make of it?
I am imagining that the 260 is going to be flying 2-3 times the altitude you normally fly the Fun Cub, perhaps to the level of the surrounding hills and your flight area grows considerably because it will be well above the tree clutter.  And you install some sort of tracking beacon so that you can locate the big beastie.
Time to create page: 0.882 seconds
