- Thank you received: 2067
Open Workshop Day - Shuttleworth Collection
- Squirrelnet
A good display of machines this year probably the best I have seen in the last 3 years of attending the event.
The Bristol Scout was great to see again now thoroughly ingrained with black castor oil and probably looking the most authentic to service use of any aircraft of the collection.
The Spitfire Vb is nearing completion. They've done some power runs but its not yet flown after its rebuild, hopefully next year
The Avro 504K was in for its yearly checks, I have to say I'm not a fan of the current scheme I still think of it in the old RFC scheme in PC10 and roundels.
- Squirrelnet
Tucked away in the rear workshop normally out of sight to visitors was the Bristol monoplane now undergoing repairs after a 'heavy landing'. Incidentally I love the trophy wall behind , reminds me of a WW1 Pilots mess
Here a knowledgable Engineer explains to the pilot what wiggling the controls actual does !!
- Squirrelnet
If this wasn't enough the rest of the museum offers more Sopwith tails than you can shake a stick at and more besides
Highlight of the day for me was getting up close to the Bleriot, currently minus its engine
But the best bit was reading the pilots notes. see below... :S
'Avoid the use of the stick... [as it] will result in turn the wrong way' !!! ...errrr :blink:
'Reduce power slowly to avoid pitch-up before landing' ...it pitches UP when you reduce power !!! ...errrr :blink:
'If directional control is lost after landing and catchers are approaching the aircraft - stop the engine' ..it has marginal directional control ...errrr :blink:
- Thank you received: 14470
I've got a CD-ROM full of images, somewhere!
Got inside the Mossie at Hatfield house, too, with no problems, up the steps and into the open under-nose hatch.
Same at Duxford, before they built the new UK hangar. Everything was crammed in so tightly there was no room for barriers - apart from in the workshops, where things were in bits.
This was before certain groups began destroying things, though!
"before certain groups began destroying things though " ??????????? Can you clarify? Who would do such a thing ??Eric wrote: Last time I was at O.W. there were no 'barriers'. Just nominal guidelines of bits of tape, often tied to the aircraft struts, and nobody objected if you stepped over and peered inside, preferably with a camera poised. Often there were trays of fabric scraps and broken/life-expired/discarded bits by the aircraft, with signs to help yourself!
- Squirrelnet
There's obviously a slight bias in the photos
The Mew Gull suffered a loss of its Air Speed Indicator during the show so after a pause it came into land escorted by the Lysander which flew at the correct approach speed slightly above correct approach angle . The Mew Gull, it appears , needs a fairly precise speed to land safely.
If I recall correctly, a 'real' Lysander's cruise speed is somewhat less than the Mew Gull's stalling speed! [badass]
- Squirrelnet
That Lysander is a Comet!
Yeah not an illustrative picture...except for the Mew Gull bit. The Lysander/Mew Gull incident happened right in front of me. I thought they were just showing off at the time landing in tandem , it was only the commentary later that explained what was going on. It worked well though, the Lysander accompanied the Gull for the entire approach the Gull only overtaking once it was scooting along the runway... actually I guess the Lysander slowed down
- DeeBee1
- New Member
- Thank you received: 11
