- Thank you received: 10844
A 4M span glider 1/4 scale of the ZSD PIRATE
Starting with the fuselage formers
Whether I can get the pics to load is another mater
Can I have the old site back please
That did not work, three different pictures loaded, and look what I got
I hare this new site
- Thank you received: 14473
Strictly not quite 1/4 scale as the full size was only 15m.
I have actually flown a full size SZD Pirate a few times.
A popular all wood glider but later in its life suffered glue problems causing de lamination so in 1970 its maximum permitted speed (VNE) was significantly reduced and aerobatics prohibited, which rather limited its usefulness to gliding clubs.
Im not moaning about it being hot, you'l never here me complain about the heat, just stating the fact that its very hot just under the tin roof where my head has been for the past few days
English through and through
A classic case of the 'benefit' of communist state control as SZD gliders became a major designer & supplier for both club and competition gliders producing several thousand from 1956. The business struggled on after the fall of the communist government in Poland but ceased trading in 2007.
Its all a pain in the arse as far as im concerned, i hate using the things :evil:
Still not got my camera working
i cannot be doing with this new format, it dont work for me thats for sure, not worth posting
I've found it easiest to put the pic's on first, then if they 'stick', I edit, and add the text after, then all the typing isn't wasted!
Perhaps Pol will give Mike a kick, and he can sort it out.
This text was written after the picture was inserted.
Size is 750 x 563 px.
Edit
It has worked so the issue appears to be due to some part of the process you are using.
That one pic wouldn't even attach in a completely fresh post, several hours later.
still no pictures, i need to down load from my ipad to this comp but cant seem to be able to, been told it is because the comp is HP and the ipad Apple, im taking pics with the ipad but cannot use for writing
