KAMCO KAVALIER
but stuffed now as i cant put the painted bits outside to dry and i now cant do any sanding in the shed.
- Grumpy42
Tony B. AKA Blooper wrote: second coat of purple on the fuselage and the first coat on the top of the wing.
He, he, he - we can't slow him down but good old English weather can. Praise be to the gods of weather!
you wait till i get a bigger shed, i can have a painting room.
then we will see.
may your ic motors all run perfectly.
- Grumpy42
then we will see.
Thankyou my Son - Blessings be upon you and may your Lipo's never explode.:lol:
- Dean M
- Thank you received: 326
Got my plans laid out ready!!
Which one will fly first Kadet or Kavalier?
I nearly choked on my latte.
kavalier once i get enough funds to buy the motor i need.
Then i left it for the rest of the day and did mustang and lancaster jobs.
Came back at tea time and stuck the wing on for a look see.
needs the yellow stripe and 2 coats of polyc yet, then a motor and we can do the nose.
but we are getting there at last.
- Dean M
motor
esc
mounting kit
prop
prop adaptor
have been ordered from hobbyking uk.
£37 including postage.:ohmy:
540 watts on a 3s with a 11x5 prop should get this 4.5lb beast flying.
- Sangoma
Tony B. AKA Blooper wrote: So this morning i painted the underside of the wing and fuselage.
I think it should be called Fanta Grape :lol:
once the motor i have ordered gets here we can fit it out and make the nose up.
that will give me two kamco models to maiden at some point.
then maybe i can get some more work done to the Lancaster and mustang and viscount and cirrus moth or even start the 100" p38.
- Dean M
Is it stinky fuel proof or does it need treating?
Thinking about giving it a try, I have only ever used iron on coverings
Dean
polyc is easy to apply, has no smell and is fuel proof.
it can be used with nylon, glass mat, tissue or straight onto wood, you will need to seal the wood first though.
dry in 30mins.
i tend to use it because i am old school and was using tissue and dope.
lay the tissue on the surface and paint polyc on top, starting in the middle and working out to the edges, you can lift the tissue off and move it anytime before it dries, just re-brush the surface to smooth it out.
leave for 30 mins and apply the second coat.
i tend to use 3 coats then paint, then 2 or 3 more coats after that.
the hurricanes were done with it, hell all my builds are done with it.
some people can get on with it others cant.
