Mamselle by Vic Smead
The prop would stop very quickly in contact with water.
Maybe in your concern about a soggy airframe you did not actually turn the engine over before putting it away.
I would have to agree shearing a gudgeon pin is unusual, normally the con rod bends before that happens, maybe it was already cracked.
What does the break look like? A fatigue crack leaves a distinctive pattern.
- Thank you received: 14473
If it is the crank-pin, they were often just pressed into a drill-hole opposite the balance weight on the shaft.
For it to be pulled out (most unlikely) it would have had to pull the piston casting to bits, so there would be some bits of metal in the crankcase as well.
I'm stumped with that one!
Perhaps it seized at tdc, and the stress sheared the pin?
