- Thank you received: 14470
Electric Fox glider
30 May 2011 04:17 #1
Electric Fox glider was created by Eric
Some of you might have seen the thread on t'other forum regarding the Revolutionhobbies (Hong Kong) fox. Well, I put my pennies where my mouth used to be, and sent for one.
pics below before I begin sticking a to zee - and try to decypher the rather quaint chenglish instructions!
Well packed in a foam plastic box, then bubble-wrap, then the card box
plenty of decoration on the card box!
Every component group is bagged, the bag is bubble-wrapped, and then comprehensively taped to the box, so it cannot move.
Glass fuz, wood wings, 2.4 gig radio, servos, extension leads, speedo, lipo, motor, prop, nuts and bolts, and a cuddly toy.
More to follow when I begin sticking it all together.
- KIWI
30 May 2011 15:56 #2
by KIWI
Replied by KIWI on topic Re: Electric Fox glider
here you go tony . its called revolution shop but is actually a chinese trade company
Link is
www.r2hobbies.com/eng/products.php?cat=101
Hope that works for you .
Ive bought alot of goods and sold on from them and they are excellent to deal with , there servos are all off brands some good some bad , i bought eurgle servos and havent had any trouble with any. also look at there accessories , they sell extension leads for next to nothing.
Cheers
That bloody kiwi.
Link is
Cheers
That bloody kiwi.
08 Oct 2011 20:22 #3
Replied by Eric on topic Re: Electric Fox glider
I have finally (ahem) begun to stick the bits together, so stand by for a few pics soon. (as and when)
Here is the vast array of wooden bits that have to go in - (when I figure out what they are!! I know the round one is the motor mount, and....
09 Oct 2011 21:06 - 09 Oct 2011 21:20 #4
Glider FOX is the small-sized advanced electromotive R/C glider which it is designed is produced low price and the high performance as a fuselage. The main tail assembly which has the rib group structure due to laser cutting and we have become up-to-date best constitution the lightweight body by FRP depending upon. In addition, it designates the main wing span as 1500 mm size, it has made the size which is compatible the ease of conveyance with the air performance which has the sense of security by the fact that it makes the installation by the carbon shaft. The up-to- date brush less motor, it is optimum size to also loading the lithium polymer.
It is something in order to finish in the fuselage where this book assists the production of FOX, is better accurately. Furthermore it is improved this book by reference and, compared to the high performance becoming the fuselage, it expects that you can obtain many joys.
Furthermore, this instruction manual is drawn up on the basis of the kit of the early lot. Therefore after that, concerning the part which is improved because also the place where it is different from explanation more or less it is, please acknowledge.
And that's just the intro!!! :dry:
If you want the full eight pages of pdf, let me know, and I'll post it to your email, so you can try to figure out what it means!
Last edit: 09 Oct 2011 21:20 by Eric. Reason: added a comment!
Time to create page: 0.494 seconds
