Kalt Space Baron Heli Assembly and Setup
- Grumpy42
14 Feb 2013 14:35 - 14 Feb 2013 14:41 #1
by Grumpy42
Kalt Space Baron Heli Assembly and Setup was created by Grumpy42
I decided to start a new thread for this build and hopefully it will stay on thread. hint, hint. The "Moron" thread has sort of gone off subject but it's to much fun to ask Garry to clean it up - it is a perfect proof that there are other bloody Morons besides myself on this forum. :lol: :lol: :lol:
OK Nuff said - the Kalt Space Baron Build thread -
The firs thing I noticed is that building a helicopter is VERY different from building a fixed wing model - the balsa knives, the coping saw, the glue, the sanding tools, the pins and all the rest of my trusty arsenal could just as well have been thrown in the bin ! Even the perfectly flat building board is not absolutely necessary.
So - it's more like putting something together from a Meccano or similar construction set. The tools required consist of a small assortment of screw drivers - a small spanner or two, a vernier caliper, a dial indicator and the ability to read the fractured English of a Builders Manual. Luckily said Builders Manual is amply illustrated.
The model had been previously assembled but was broken down into sub assemblies for transport via Australia Post. It arrived in a large cardboard box that had thankfully been packed by some one who knows just how much Posties throw stuff around. It arrived battered but unbroken.
There's supposed to be a photo here
First job was to re assemble the main body and ensure every nut and bolt was tight and that the engine, main rotor shaft and associated gears were all aligned correctly. I also screwed on the skids.
Then the tail boom needed to be added and the tail feathers fixed and aligned. It's a good idea to make sure the tail rotor blades have enough room to clear the tail feathers and that the tail boom is correctly located all the way into the main body. The Manual suggested the head of the shaft should go into the body a distance of 54 mm - i found after several tries that it was correctly messed at 52.5mm.
Then comes the main rotor head. This is a fiddly job and requires several adjustments to get every thing aligned and checking the main rotor shaft with a dial indicator for any sign of run out is essential. Connecting up all those links is a small nightmare in it's self - count them ! there are 16 and every one is articulated.
OK - that's the easy part - the next installment will be balancing and fitting the main rotor blades and installing and connecting up the servos and the bloody gyro. After that it's a matter of setting everything up correctly - stay tuned.
I'm sorry about the photos but the damn things just won't load - if this uploads successfully I'll try the photos again
Last edit: 14 Feb 2013 14:41 by Grumpy42.
- Grumpy42
14 Feb 2013 14:39 #2
by Grumpy42
Replied by Grumpy42 on topic Kalt Space Baron Heli Assembly and Setup
OK that worked without a problem - now we try the photos
If this works the photos are in the same order as the comments.
Attachment not found
- Grumpy42
14 Feb 2013 14:39 #3
by Grumpy42
Well I'll be damned - it worked !!!
- Thank you received: 14471
14 Feb 2013 19:46 #4
Replied by Eric on topic Kalt Space Baron Heli Assembly and Setup
Don't forget to use plenty of thread-lock, or the first time you start the lump up, all the screws will fall out! haha! (All that lovely vibration from out-of-balance oscillating lumps of scrap metal!) :ohmy: :woohoo:
- Grumpy42
15 Feb 2013 19:08 - 15 Feb 2013 19:08 #5
by Grumpy42
Damn - tried to load the next batch of photos and text about 20 minutes ago - no bananas - got some sort of error messages and my computer crashed !!!! Will try again tomorrow I guess.
Last edit: 15 Feb 2013 19:08 by Grumpy42. Reason: F'd up!
- Grumpy42
16 Feb 2013 13:36 - 16 Feb 2013 13:37 #6
by Grumpy42
Iam now going to try to load a couple of those photos I screwed up yesterday: -
Got the rotor blades balanced and fitted - screwed up the photos though, Oh well - here's the end result - and I've got the servos in place. Now all I need is to fit a gyro - Any Suggestions or advice please - Apparently I need a holding heading (HH) type and it should be connected to a digital servo because of the response times.
Please remember I'm a complete bloody beginner when it comes to RC Heli's but I did try to include as clear an illustration as possible of the PROPER engine installation. :evil: :evil: :evil:
Last edit: 16 Feb 2013 13:37 by Grumpy42. Reason: The usual
16 Feb 2013 21:58 - 16 Feb 2013 21:59 #7
That's a Heading Hold gyro! In other words, it stops the tail end flailing merrily around by applying yaw control without you touching the stick - once it is set up properly! -
All gyros do this, and if you are feeling rich, you can get a three-way gyro, that controls heading, and cyclic pitches, to help you hold the weed-whacker in a hover.
Some of them even have a 'gain' control (sensitivity) that is operated by another spare channel on the tx/rx combo.
A basic one channel gyro will cost you the exorbitant sum of about a tenner (In English money), and should be located, the right way up and round, as close to directly under the main rotor shaft as you can get it.
:oops: Just realised - I'm trying to help a petrol-head! AAARGH!
Last edit: 16 Feb 2013 21:59 by Eric. Reason: added a comment
Time to create page: 0.950 seconds
