TELEMASTER
19 Aug 2013 09:28 #1 by Ex-Member
TELEMASTER was created by Ex-Member
Well the plans for the next little project have turned up.
fuselage plan, its only 7'6" long. :woohoo:
one wing panel.
need to work out all the wood i need for it now, ready to buy at the nats.
19 Aug 2013 17:45 #2 by Garry Pollard
Replied by Garry Pollard on topic TELEMASTER
Now look what I have done to Mr Master Builder. :( :( :( :( Mention something, and away he goes again :woohoo: :woohoo:
19 Aug 2013 17:51 #3 by old fart
Replied by old fart on topic TELEMASTER
What's it's wingspan? :)
19 Aug 2013 19:20 #4 by Ex-Member
Replied by Ex-Member on topic TELEMASTER
12ft or 144 inches or 3.6m
bloody big builds i get stuck with.
19 Aug 2013 19:47 #5 by Quorneng
Replied by Quorneng on topic TELEMASTER
Tony
Is the Telemaster yours (where do you put it?) or are you building it for someone?
19 Aug 2013 20:00 #6 by Ex-Member
mine!!! Ha Ha
nothing is ever mine.
i have 2 models that are mine and one of them is an artf. :P
19 Aug 2013 20:46 #7 by Ex-Member
got the fun job of sitting down on the floor with 10 miles of plans and try to work out what wood i need to buy at the nats.
it's all in imperial, so i will have to convert everything to metric and make a HUGE list.
bound to forget something though.
might need an artic to get the stuff back home. :P
  • Dean M
21 Aug 2013 09:24 - 21 Aug 2013 09:26 #8 by Dean M
Replied by Dean M on topic TELEMASTER
Looks interesting tony, look forward to this one
Have you seen this one on YouTube? It is Electric powered although it is the ARTF version
I nearly choked on my latte.
Last edit: 21 Aug 2013 09:26 by Dean M.
21 Aug 2013 09:33 #9 by Ex-Member
i spent an hour last night with the 10 sheets of plan trying to work out what wood i need.
its all in imperial measurements :P
got a rough idea now, but i expect i will miss something and have to order it later.
still i should be able to get the basic frame done fairly quickly.
might get 3 ribs cut from each sheet of balsa if i am lucky.
21 Aug 2013 12:53 #10 by Quorneng
Tony
At that size I would have thought it would be possible to use 'built up' wing ribs and save on a lot of sheet balsa! ;)
21 Aug 2013 12:58 #11 by Ex-Member
i am thinking of making a jig to make them out of strips of 3mm balsa.
anyway.
got bored waiting for some glue to dry.
fin under construction.
its all made from 3mm strip with 9mm square leading and trailing edges.
21 Aug 2013 14:58 #12 by Ex-Member
fin and rudder all built up.
need to sand them smooth and then sort out hinges, control horn and tail wheel mount.
21 Aug 2013 15:32 #13 by Garry Pollard
Hells Bells, slow down Mr Master Builder, I havent got the Lanc yet :woohoo: :evil: [badass]
21 Aug 2013 18:43 - 21 Aug 2013 18:46 #14 by Ex-Member
10 ribs for the tail plane cut, need to cut the slots for the ribs and then cut 4 more for the center section.
the whole tail bolts on, so the center ones are a bit more complicated.
run out of 3mm balsa now anyway, so no more till after the nats.
the issue was that i only had a view of the center ribs, i have had to extrapolate what the rest look like.
Last edit: 21 Aug 2013 18:46 by Ex-Member.
27 Aug 2013 15:15 #15 by Ex-Member
well i am back from the nats (excellent time) with a boot full of balsa wood.
sooooooooooooooooooooooooo
after clearing some bits out of the workshop (i need more room, or less models) i did a little bit more.
finished cutting the ribs and cut some strip (thick strip) and started building.
The tailplane is 4ft wide, thats the same size as my funfly main wing. eeeeeeeeeeeeeeeeeeeeeeep.
i need to make up the ply center ribs and wing braces and wing mounts next, then i can put the leading and trailing edges on and start the elevators.
Time to create page: 0.852 seconds
