Boulton Paul Defiant
- Thank you received: 14473
be ready for cutting tomorrow.
then i can start drawing the next one in the model line.
Depron would certainly work at that size. It would be lighter (and cheaper) so would need less power which would save weight so it would be lighter..........
The only problem going too far down that route is it ends up flying slower and gets thrown about more in turbulence which tends to limit the maximum wind speed it is practical to fly in.
then take some more, glue together and carve the canopy.
glue 5 bits of 6mm together and carve into the gut turret and the tail fairing and we have a defiant.
need to sit down and draw the tailplane next, that will be solid 6mm as well, then i can look at the main wing.
pin the bottom spar down and glue the ribs on, remembering to angle the root rib for the dihedral.
[img]http://http://i5.photobucket.com/albums/y185/MUDDYJLX/Boulton%20Paul%20Defiant/DSCF0657_zps63eed02d.jpg[/img]
then glue the top spar, leading edge and aileron spar.
build the second wing panel in the same way.
join together.
test for fit.
then join to bits of 6mm together and cut the tips out.
glue on and leave. will shape them once the sheeting and cap strips have been fitted.
stuck now as i need to order some more 1.5mm balsa wood.
