Boulton Paul Defiant
24 May 2014 19:01 #1 by Ex-Member
Boulton Paul Defiant was created by Ex-Member
Thought i would start drawing again this afternoon.
Profile model of the above aircraft.
built up wing at 34" wingspan.
flat fuselage sides.
6mm solid flat tailplane.
3 chan for 3s electric .
24 May 2014 19:20 #2 by Garry Pollard
Replied by Garry Pollard on topic Boulton Paul Defiant
That looks nice Tony, looking forward to this one
24 May 2014 21:19 #3 by Ex-Member
Replied by Ex-Member on topic Boulton Paul Defiant
AT that size Tony, it might be a good place to start depron building........what do you think Q and Monz?
24 May 2014 22:15 - 24 May 2014 22:18 #4 by alan cantwell
Replied by alan cantwell on topic Boulton Paul Defiant
let me know when you have a zenoha 62powered version, meanwhile, best of luck with an aircraft that in the UK, only you are doing a model of :)
Last edit: 24 May 2014 22:18 by alan cantwell.
24 May 2014 23:39 #5 by Eric
Replied by Eric on topic Boulton Paul Defiant
You could say that Tony is defying the trend! :P
25 May 2014 11:19 #6 by Ex-Member
adding the fuselage formers today and hopefully get the wing design sorted.
be ready for cutting tomorrow.
then i can start drawing the next one in the model line. :P :P
25 May 2014 12:03 #7 by Quorneng
Replied by Quorneng on topic Boulton Paul Defiant
Tony
Depron would certainly work at that size. It would be lighter (and cheaper) so would need less power which would save weight so it would be lighter..........
The only problem going too far down that route is it ends up flying slower and gets thrown about more in turbulence which tends to limit the maximum wind speed it is practical to fly in.
25 May 2014 13:31 #8 by Ex-Member
well i decided to crack on with a balsa version for now.
take 1 sheet of 3mm balsa and some offcuts of 3mm lite ply and 1 hour later.............. :P
i said it was not going to be scale didn't i, the idea is do do it as simply as poss but still make it look roughly like the intended aircraft.
25 May 2014 15:43 #9 by Ex-Member
take some 6mm balsa offcuts and make the fin and rudder up.
then take some more, glue together and carve the canopy.
glue 5 bits of 6mm together and carve into the gut turret and the tail fairing and we have a defiant. :P
need to sit down and draw the tailplane next, that will be solid 6mm as well, then i can look at the main wing. :P
25 May 2014 19:36 #10 by Ex-Member
drawn and cut out the tailplane and elevators now.
next is the wing design and build.
26 May 2014 14:52 #11 by Ex-Member
plans are all drawn up now.
need some more wood now before i can build the wing and finish it off.
26 May 2014 15:13 #12 by old fart
Replied by old fart on topic Boulton Paul Defiant
I thought you were supposed to draw the plan before you build it. :P :P :P
26 May 2014 21:07 #13 by Eric
I don't! I build a model, then if it works, I draw around the bits. If it doesn't fly very well, there usually aren't enough bits to draw around! [badass]
27 May 2014 18:21 #14 by Ex-Member
sat down and cut all the wing ribs, spars this afternoon.
pin the bottom spar down and glue the ribs on, remembering to angle the root rib for the dihedral.
[img]http://http://i5.photobucket.com/albums/y185/MUDDYJLX/Boulton%20Paul%20Defiant/DSCF0657_zps63eed02d.jpg[/img]
then glue the top spar, leading edge and aileron spar.
build the second wing panel in the same way.
join together.
test for fit.
then join to bits of 6mm together and cut the tips out.
glue on and leave. will shape them once the sheeting and cap strips have been fitted.
stuck now as i need to order some more 1.5mm balsa wood.
28 May 2014 18:12 #15 by Ex-Member
managed to scrape together some scraps of 1.5mm and almost sheeted the top of the wing.
needs the trailing edge and cap strips to complete the top.
Time to create page: 2.089 seconds
