depron Jet
but if it had worked i would have had the data needed to move onto the mk 2 with control vanes in the edf outlet.
bit moot now as it didn't work anyway.
- Thank you received: 10844
it was too heavy for the thrust.
now we need to think about the mk2.
i need some efecient way of directing the thrust from a fixed fan, yes the harrier did it i know but that is very complicated to replicate in a model.
again we are talking about weight.
HK do a 1600mah 4s lipo that weighs less than the 2200mah 3s i was using ( but that costs money) so that would give more thrust.
hmmmmm thinking cap time.
suggestions accepted.
You might do better using one fan (or more) for lift and another smaller one for thrust (like the Short SC1) then you don't have to worry about vectoring anything but, and it is a big but,you still have to find a way of keeping the thing stable when its 'balancing' on a column of air!
plan b is to not build an aircraft at all, but something similar to the flying bedstead to see if i can get a hover first.
fixed outlets with deflectors inside to direct the airflow ( badly)
weighs 130gms at the moment with the 65mm edf.
with 3s lipo i can get 210gms of thrust.
with 4s lipo we can get up to 310gms of thrust.
now the 3s lipo weighs 190gms, so it dont leave much to play with
but i can get a 1600mah 4s lipo that weighs less then my 2200mah 3s.
soooooooooo
the crapasus engine weighs 130gms.
the depron jet airframe weighs 130gms with 3 servos.
the esc and rx comes in at 50gms
and the 4s lipo (when i can afford it) weighs 190gms.
total 500 gms.
not enough oompf
hmmmmmmmmm.
the motor unit has gone up in weight to 140gms now.
so with 3s lipo we got 250gms of thrust.
and with the 4s we are up to 350 gms.
so an improvement by just fitting a duct.
need to think how i can get another 50 gms from the set up now and we might be able to build a light airframe for hover testing.
then we can think about the mk3 setup with moveable nozzles and a redesigned plenum chamber.
Very interesting Tony
Tony B wrote: i made up an inlet duct for the edf and had another go.
Good try Tony Might I suggest smoothing the intake and removing the obvious step or ledge I also remember some narrowing taper had given extra thrust by building up some pressure immediately before the nozzle outlet. A bit like squeezing the end of hose to project the jet further. I don't know the ins and out exactly but I think there details on line
For maximum static thrust I would avoid a 'built up' inlet all together and use the EDFs own bell mouth.
What 65mm EDF is it that you are using?
still i now have ideas for the mk3 set up, so i might just redirect the outlets on this one and fit it into an airframe and see if it will fly ass a conventional aircraft.
came out worse than i expected.
with all the gubbins the motor had to lift 169gms plus the loading i put on.
working up in increments on a 4s lipo it stopped lifting at 120gms.
so that only gives a total thrust of 289gms not the 350 i had with the old testing method.
so this one is toast and we go back to the drawing board.
- Thank you received: 14473
If you balance the 'saw' with equal lengths either side, the scale will be reading 1/1 (minus friction of the pivot), make it two to one, and divide the weight by 2, etc!
