- Thank you received: 45
- Neddy
- Junior Member
- Crashrr
- Senior Member
- Thank you received: 284
- Mike Rolls
- Thank you received: 573
- Ralpharr2001
- Thank you received: 1484
- Ralpharr2001
I can crack on with the front of the fuselage now and build the motor mount box.
- Ralpharr2001
Basically as designed by Vance Mosher the tailfin, tailplane and rudder is a single assembly that can be removed to access the rudder and elevator servos. The challenge was how? So I tackled the fin and rudder assembly first and sanded it down until it went together and operated quite smoothly. The fin tailpost sits down into the tail so I have glued a 3mm clinch nut to the fuselage then screwed the tailpost to it.
With the 3mm bolt in the tail post hat should hold the whole assembly into place and still be removable. The rudder has removable hinge pine so the rudder comes off to access the 3mm bolt.
The tail fin and rudder is glued to the tailplane which has two dowels at the front to locate it into the fuselage. Now the whole assembly:
Having nearly got this sorted i've got a bit more confidence to press on with the build. A lot of sanding and filling to do on the tail feathers but very close.
- Thank you received: 10844
- Ralpharr2001
- Ralpharr2001
You can see the difference in the photo's:-
I'll post some photo's after the glue has dried.
- Ralpharr2001
- Ralpharr2001
The plan for tomorrow is to cut all the parts for the flaps which involves more metal work. Can't wait! :whistle:
- Ralpharr2001
