A new design
  • Dr Rocket
  • New Member
  • New Member
30 Jul 2019 14:04 - 30 Jul 2019 17:36 #1 by Dr Rocket
A new design was created by Dr Rocket
A few months ago I started on a new design for Liverpool Hope University. We're looking at small solar winged aircraft as a platform for research and interesting student projects. Its a subject that's interested me for many years, and I figured it was time to put my design and building skills to the test.
The concept is to build a small (3-4m wingspan) aircraft that can stay aloft for many days. Larger solar aircraft have been built and flown, for example Solar Impulse and Zephyr. The challenges of miniaturizing everything for a much smaller aircraft set my mind racing. Working with one of our PhD students we made a software model of the aircraft and showed that the idea is credible on paper.
We've broken the project down into a series of phases of increasing complexity. This first phase is to develop construction techniques for an extremely lightweight and low power aircraft. Over the summer break I've started the deep design of our first prototype so the project is truly underway!
Just to whet everyone's appetite, this is the CAD drawing for the first version of the left wing. Spars are carbon fibre, leading and trailing edges are balsa. The inboard 3 ribs are 3D printed for strength, and the rest will be 3mm Depron for lightness. Its beginning to take shape on the mag table. Once assembled I'll start to investigate ways to simplicate and add lightness to the design.
Last edit: 30 Jul 2019 17:36 by Klipkopwildlife.
Thanks: Klipkopwildlife, Ralpharr2001, crash happy
30 Jul 2019 15:06 #2 by Quorneng
Replied by Quorneng on topic A new design
Dr Rocket
Interesting!
I suppose my first observation is "many days at a time". This could raise a potential "line of sight" issue if it is to be flown in the UK without special CAA permission.
Just a thought but does a high aspect ratio wing give the best area to weight ratio for a solar powered plane?
It is possible a more 'modest' wing design could end up providing a better compromise between structural and aerodynamic efficiency.
  • Dr Rocket
  • New Member
  • New Member
30 Jul 2019 16:08 #3 by Dr Rocket
Replied by Dr Rocket on topic A new design
We've already been in contact with the CAA and both parties think that the best approach is to set up a TDA for trials. This could give up to 90 days window for test flights. Initially we want to develop and prove all the strands of the technologies, so we're probably not going to get to the overnight stage for about 2-3 years. Who knows what CAP 722 will look like by then! We have a fallback position at an overseas university should UK regulations become unworkable.
The wing is one of the key challenges. The upper surface is to be covered in solar cells (we have a source of very lightweight flexible cells) so it will have to be strong enough to support them and their cabling. Energy management is the biggest challenge so we see automated soaring as one energy saving measure, hence the glider-like profile.
For this proof-of-construction-concept phase I'm going for a simple 13% Clark Y as its easy to build. We want to understand construction issues such as where we can save weight, which materials work and which don't, how much flex we can expect (solar cell fatigue over a long flight is a concern). The next version will probably be one of the Eppler profiles with some tapering and a bigger root chord.
30 Jul 2019 17:25 #4 by Eric
Replied by Eric on topic A new design
Without intending to throw cold water on your ideas, why are you trying to re-invent the wheel?
A solar-powered UAV has already been built and flown, a couple of years ago, as a flying test-bed for an airborne radio relay system.
It was basically a huge flying wing, with multiple motors, but proved so fragile, to minimize weight, that it couldn't be flown in anything except a flat calm, or the clear air turbulence broke it!
If I recall, it was intended to drift around in the upper atmosphere, way above present aircraft, using battery at night, and solar during the day.
After a few trials, everything went very quiet.
www.unifly.aero/news/solar-powered-drone...fly-for-up-to-a-year
30 Jul 2019 17:42 #5 by Klipkopwildlife
Replied by Klipkopwildlife on topic A new design
Eric, I don't think Doc is re-inventing the wheel so much as to give ideas for course material and to get students creative juices flowing. Yes it's been done before but can it now be done better? And enable UK technology to steal the march on the rest of the world. I imagine someone very high up has made a sizable amount of money available to kick start this.
Thanks: crash happy
30 Jul 2019 19:05 #6 by paul d
Replied by paul d on topic A new design
Eric wrote: Without intending to throw cold water on your ideas, why are you trying to re-invent the wheel?
Very helpful I'm sure....
30 Jul 2019 19:19 - 30 Jul 2019 19:21 #7 by crash happy
Replied by crash happy on topic A new design
As one of the unenlightened can someone please explain the advantages of using an Eppler profile as opposed to the Clark Y ?
Last edit: 30 Jul 2019 19:21 by crash happy. Reason: finger trouble
30 Jul 2019 19:23 #8 by Klipkopwildlife
I'll deal with it in Technical Crash.
Thanks: crash happy
30 Jul 2019 19:55 #9 by paul d
A truly fascinating project DR,
I'm a complete electrickery numpty but I'd love more details, energy management etc.
  • Dr Rocket
  • New Member
  • New Member
30 Jul 2019 20:07 #10 by Dr Rocket
Hi Eric. No cold water there! The Aerovironment/NASA projects like Helios contributed a lot to solar aircraft development, mainly through NASA's open approach to publishing data. Since then the much publicised Solar Impact has flown around the world, and Zephyr has shattered its own endurance record with a 25 day flight. I was involved in Zephyr before 'retiring' to part-time academia. Another academic institution (ETH Zurich) has completed a 4-day flight with a 5.6m solar aircraft. Aeromodellers have managed flights of a few hours using a mix of solar and battery, and some of these are on You Tube.
As a research project we want to see how small a functioning aircraft we can build. There's loads of interesting tech to explore there. I'm currently on the prowl for a new PhD student to explore some of our ideas. For the undergrads and masters students there's a shedload of interesting projects, especially for the robotics and electronics students.
Regarding Eppler: its a matter of getting a low speed & Reynolds number, high lift/drag ratio aerofoil. The Eppler series are particularly well suited to that flight profile.
30 Jul 2019 20:19 #11 by paul d
So that's you told Eric!
Truly fascinating DR, thank for that, I will be following with interest.
  • Dr Rocket
  • New Member
  • New Member
30 Jul 2019 20:24 #12 by Dr Rocket
Hi Paul. At a purely electronics level there's not much new in energy management for a solar aircraft. Solar panels feed a max power point tracker (project - MPPT needs to be miniaturized) and voltage converter to provide core power. Excess power is used to charge batteries, which release power overnight.
Algorithmically its a whole new game! Kinetic and potential energy are negligible, so the strategy for managing electrical energy is key to success. Airspeed has to be slow to keep propulsive power low, especially overnight so the aircraft can fly to well beyond dawn on stored energy. Decisions to climb (high power) need to be made when there is excess solar power, so climbing at night is unlikely except in dire emergencies.
Research and simulations suggest that flying the aircraft is the easy bit. Most of the operational effort revolves around planning the generation, storage and consumption of energy.
30 Jul 2019 20:47 #13 by paul d
Thanks, it'll take me some time to digest that, wonderful project and I wish you every success.
30 Jul 2019 21:34 #14 by Eric
I think I'd better stick to feeding my hedgehogs! (Facebook, if you are sufficiently interested!)
Clark Y is a very old RAF wing section, thick and draggy, but stiff enough for strong structures without lots of external bracing, used on the early monoplanes. As it has an effectively flat bottom, it is easy to build straight.
Eppler 374 is - or was - a popular slope-soaring section - a semi-symmetrical section to look at, but in reality it is slightly undercambered - works ok inverted, which is irrelevant for this purpose.
E 195 is/was one for higher speed flight, cross country comp's etc. but might be too slim for your purposes, as it doesn't have the depth, so needs a stronger spar - visibly undercambered.
There are, of course many many more.
30 Jul 2019 23:50 #15 by Quorneng
I would agree entirely that minimising the power to fly is an key factor for this sort of project.
Power to fly is a function of a plane's total weight and its 'gliding' sink rate.
My own experiments in duration power flying suggest this is not necessarily achieved with typical high aspect ratio glider wings which are intended to achieve the best lift to drag ratio but have a structural weight penalty rather than obtain the minimum power to maintain level flight.
Your team could be in for quite a bit of experimentation.
I will follow with interest.
Time to create page: 1.317 seconds
