- Thank you received: 27
A new design
- Dr Rocket
- New Member
The concept is to build a small (3-4m wingspan) aircraft that can stay aloft for many days. Larger solar aircraft have been built and flown, for example Solar Impulse and Zephyr. The challenges of miniaturizing everything for a much smaller aircraft set my mind racing. Working with one of our PhD students we made a software model of the aircraft and showed that the idea is credible on paper.
We've broken the project down into a series of phases of increasing complexity. This first phase is to develop construction techniques for an extremely lightweight and low power aircraft. Over the summer break I've started the deep design of our first prototype so the project is truly underway!
Just to whet everyone's appetite, this is the CAD drawing for the first version of the left wing. Spars are carbon fibre, leading and trailing edges are balsa. The inboard 3 ribs are 3D printed for strength, and the rest will be 3mm Depron for lightness. Its beginning to take shape on the mag table. Once assembled I'll start to investigate ways to simplicate and add lightness to the design.
Interesting!
I suppose my first observation is "many days at a time". This could raise a potential "line of sight" issue if it is to be flown in the UK without special CAA permission.
Just a thought but does a high aspect ratio wing give the best area to weight ratio for a solar powered plane?
It is possible a more 'modest' wing design could end up providing a better compromise between structural and aerodynamic efficiency.
- Dr Rocket
- New Member
The wing is one of the key challenges. The upper surface is to be covered in solar cells (we have a source of very lightweight flexible cells) so it will have to be strong enough to support them and their cabling. Energy management is the biggest challenge so we see automated soaring as one energy saving measure, hence the glider-like profile.
For this proof-of-construction-concept phase I'm going for a simple 13% Clark Y as its easy to build. We want to understand construction issues such as where we can save weight, which materials work and which don't, how much flex we can expect (solar cell fatigue over a long flight is a concern). The next version will probably be one of the Eppler profiles with some tapering and a bigger root chord.
- Thank you received: 14473
A solar-powered UAV has already been built and flown, a couple of years ago, as a flying test-bed for an airborne radio relay system.
It was basically a huge flying wing, with multiple motors, but proved so fragile, to minimize weight, that it couldn't be flown in anything except a flat calm, or the clear air turbulence broke it!
If I recall, it was intended to drift around in the upper atmosphere, way above present aircraft, using battery at night, and solar during the day.
After a few trials, everything went very quiet.
www.unifly.aero/news/solar-powered-drone...fly-for-up-to-a-year
Very helpful I'm sure....Eric wrote: Without intending to throw cold water on your ideas, why are you trying to re-invent the wheel?
- crash happy
- Thank you received: 1203
I'm a complete electrickery numpty but I'd love more details, energy management etc.
- Dr Rocket
- New Member
As a research project we want to see how small a functioning aircraft we can build. There's loads of interesting tech to explore there. I'm currently on the prowl for a new PhD student to explore some of our ideas. For the undergrads and masters students there's a shedload of interesting projects, especially for the robotics and electronics students.
Regarding Eppler: its a matter of getting a low speed & Reynolds number, high lift/drag ratio aerofoil. The Eppler series are particularly well suited to that flight profile.
Truly fascinating DR, thank for that, I will be following with interest.
- Dr Rocket
- New Member
Algorithmically its a whole new game! Kinetic and potential energy are negligible, so the strategy for managing electrical energy is key to success. Airspeed has to be slow to keep propulsive power low, especially overnight so the aircraft can fly to well beyond dawn on stored energy. Decisions to climb (high power) need to be made when there is excess solar power, so climbing at night is unlikely except in dire emergencies.
Research and simulations suggest that flying the aircraft is the easy bit. Most of the operational effort revolves around planning the generation, storage and consumption of energy.
Clark Y is a very old RAF wing section, thick and draggy, but stiff enough for strong structures without lots of external bracing, used on the early monoplanes. As it has an effectively flat bottom, it is easy to build straight.
Eppler 374 is - or was - a popular slope-soaring section - a semi-symmetrical section to look at, but in reality it is slightly undercambered - works ok inverted, which is irrelevant for this purpose.
E 195 is/was one for higher speed flight, cross country comp's etc. but might be too slim for your purposes, as it doesn't have the depth, so needs a stronger spar - visibly undercambered.
There are, of course many many more.
Power to fly is a function of a plane's total weight and its 'gliding' sink rate.
My own experiments in duration power flying suggest this is not necessarily achieved with typical high aspect ratio glider wings which are intended to achieve the best lift to drag ratio but have a structural weight penalty rather than obtain the minimum power to maintain level flight.
Your team could be in for quite a bit of experimentation.
I will follow with interest.
