- Thank you received: 1203
The Jekyll or Hyde
- crash happy
- crash happy
Just to be on the safe side we took it out to where he is working & let a couple of their guys have a look ( wind turbine structural engineers).
After quite a bit of pushing, pulling & prodding, their opinion was that it would have to be a pretty catastrophic "arrival" to break it. The only concern was that the tube may fracture at the cross brace in the A frame at some point. I might take another look at that. Otherwise it will remain as is. Thanks for the input though, it was worth looking into.
Here's another one to look at.
- crash happy
Full detachable wing 1840 mm.
Aileron servo cutout. Lower part of the tip is angled in the hoerner fashion, top part left flat to allow fixing of a tip fin which will start just behind the CG point.
- crash happy
I am sure even a 5g servo would be quite adequate. Remember you can (and should) use the full servo travel although it only has to move the flap by about half the angle so there is a 2:1 mechanical advantage straight away!
In addition with a bit of linkage geometry you can arrange that the servo travel is not proportional to flap travel with the result that the effective mechanical advantage to the servo rises with the flap angle.
The aerodynamic load on flaps is more or less proportional to their angle, hence the need for placard speed limits when deploying flaps!
- crash happy
Attachment not found
- crash happy
- Ralpharr2001
- Thank you received: 1484
There can be aerodynamic reasons on the position of the tail plane but for a tail dragger 'on top' of the fuselage is popular simply because it keeps it clear of the ground but less on a issue with a trike U/C.
- crash happy
I thought about plastic fins but that's to heavy & to weak, so eventually I made something in foam. I wouldn't call it a fin, more of a tip fence.
The horner tip shape remains, the fence adds some strength. I just hope it works !
- crash happy
Wing braces are 6mm ali tube slid ( & eventually glued) inside plastic edging strip, which just happens to have a nice aerofoil cross section.
These are screwed to hinges glued into the wing at one end & attached with 4mm screws into crimp nuts at the fuz. Making it easy to remove the wing for transport. The hinges are modified strip light diffuser hinges, I know i'm cheap but necessity is the mother of all invention! :whistle: The wheels in the picture are just for demo purposes, it will have grand tundra wheels when finished. [attachment=23043]
- Ralpharr2001
I love ingenuity when people adapt things like your hinges.
