- Thank you received: 1203
Tomcat
- crash happy
This will be the first model made entirely with the new foam, mostly 5 mm thick sheet. It is also the lightest, with everything weighed it looks like it will come in at around 50 oz all up, which for me at least is light ! Power comes from a g15 3520 980 kv motor spinning an 11x7.5 prop & rated a 440 watts. 60A ESC with 5A switchable BEC. I will probably run it on 3s, although there is plenty of room for a 4s. The name is taken from the motor make. I thought it quite apt, as most of my builds seem to have a mind of their own & can on occasion be a bit spiteful ! :whistle: Well at the moment it's going together okay. With the big flaps this one might actually rate as STOL. :lol: I decided to add an extra servo tor tail wheel steering.
All that weight at the back will need about four times as much at the front, to make it balance - especially as you visually intend to put the battery behind the c of g, which will normally be slightly behind the main legs.
- crash happy
- Flytilbroke
- Thank you received: 1987
- crash happy
- Thank you received: 10842
- crash happy
- crash happy
Just a mechanical point but two rigid push rods working in opposition is not a sound set up.
The servo and tail wheel arms have to be exactly the same length and parallel to each other or it will bind at some point unless there is sufficient linkage slop.
It is hard to imagine that such a substantial rod couldn't handle both the tension and compression forces on its own.
You would then be free to use the inner servo arm holes if the steering proved to need less travel.
Tail-wheel - unless you are planning on doing a lot of taxiing on a hard flat surface, I would leave it free-castoring. The tail-wheel on my Yellow Peril is free, and I have enough rudder authority to keep it more or less straight on grass, unless I'm trying to go crosswind or downwind in a stiff blow. Then it is quicker to go and collect it!
For take-off, it's only on the ground for about a second!
Learn to land so the model stops near you! [badass]
Incidentally I like the chrome effect paint, maybe you should give Martin the heads up.
- crash happy
As far as paint goes, I have written reams on it in previous recent & past posts, it's all there for the reading ! :whistle:
Eric Wrote "Learn to land so the model stops near you! " [badass]
If it fly's as slow as the Apprentice I could probably catch it on the way past ! :lol:
Just remember that with a castoring tail wheel a tail dragger is directionally unstable. Once it starts to slew it will continue and get worse until either the air speed is enough for the fin/rudder to correct it or the plane runs out of kinetic energy.
Free fully castoring on a full size tail dragger will lock the tail wheel straight ahead for take off.
