- Thank you received: 14470
Tomcat
- crash happy
- Thank you received: 1203
- crash happy
The conventional wisdom is CofG needs to be not far in front of the step so it is easy to 'rotate' to leave the water. Similarly on landing it is important to be able to keep the nose of the floats up until it stops planing and the float becomes a boat.
A side view of a DH Beaver on floats.
It is reasonable to assume the CofG is on or close to where the wing strut joins the wing.
Note the float step is not that far behind the CofG.
How does this location compare to your Tomcat?
I suspect on a model with plenty of power the take off is not the problem apart from keeping straight but landing is a different matter.
It is worth noting that the initial motor torque will tend to depress the LH float and raise the RH one. Water drag is directly proportional to displacement unlike a wheel where rolling resistance is much less sensitive to the load carried. :ohmy:
- crash happy
I have also been swatting up on the flying side. The general consensus seems to be; Nearly full up elevator & advance the throttle "smoothly" to full, once planing ease off on the elevator a bit until she lifts off, simple ! :whistle: Landing, well I will worry about that when I get to it, It's coming down one way or another !:woohoo:
- Flytilbroke
- Thank you received: 1987
- crash happy
Thanks Klippy, iv'e not heard that mentioned before !Klipkopwildlife wrote: One thing that can catch you out when landing on water is the lack of turbulence.
Water resistance is proportional to at least the square of the speed. The bottom of the floats touch first and are lower down than a wheel so a 'fast' landing with floats is much more likely to result in a nose over than with wheels. Furthermore unless you have divine powers you can't just walk over to pick it up!
- crash happy
That all makes sense. I know that our RIB can go from 35 knots to a standstill in a very short distance if you chop the throttle. As soon as it falls of the plane the bow digs in quite hard. The knack then is to do a hard 90 degree turn to avoid the stern wave catching up & filling the back with water, something that regularly catches out new recruits ! :lol: Not something I will be trying with the Tomcat though! Letting it "settle" gently seems the way go. I think I might invest in some waders.Quorneng wrote: "water friction does the rest" can also be a problem if the landing speed is too high.
- Flytilbroke
