FT Saab Viggen 70 mm EDF.
05 Dec 2020 14:28 #1 by crash happy
FT Saab Viggen 70 mm EDF. was created by crash happy
Not that sophisticated, after seeing Ralph's Firefly ! Anyway Iv'e made a start & the first tentative cuts have been made. It is quite a novelty to be working from plans for once, & I have to say It's quite therapeutic !
05 Dec 2020 15:56 #2 by Ralpharr2001
Replied by Ralpharr2001 on topic FT Saab Viggen 70 mm EDF.
Looks good Crash. I must finish the depron Buccaneer. So I'm watching this for inspiration!! ;)
Thanks: crash happy
05 Dec 2020 16:05 #3 by Klipkopwildlife
Replied by Klipkopwildlife on topic FT Saab Viggen 70 mm EDF.
Ah, confused there for a moment, the first photo is a paper template, the second is the cut part, yes?
05 Dec 2020 21:06 #4 by crash happy
Replied by crash happy on topic FT Saab Viggen 70 mm EDF.
Exactly that Klippy. To maximise the number of parts from each sheet of board, I cut them out of the plan with a small overlap & position them with painters tape, then just cut to the lines. I will keep the board, so if I want to make more parts I can simply mark round the inside of the cut-outs. :)
Thanks: Klipkopwildlife, Quorneng, THE BLACKBIRD, paul d
07 Dec 2020 18:25 - 07 Dec 2020 18:31 #5 by crash happy
Making some slow progress with the build. There are some fairly complex cuts & folds, but up to now my patience has not been tested to badly. how long that will last is anyone's guess !:whistle: I take my hat off to David Windestål, the young designer. He certainly thought it through & came up with a great design. :) The last photo is a dry fit, at least it's starting to look like an aircraft. A few more parts to make & then I will be stuck until the EDF arrives. :) Notice the two black dots near the front of the wing, that is the CG point. The nose was particularly interesting to fold to shape !
Last edit: 07 Dec 2020 18:31 by crash happy. Reason: added photo
07 Dec 2020 18:53 #6 by paul d
Replied by paul d on topic FT Saab Viggen 70 mm EDF.
looking good! what's the dimensions and predicted weight? is it possible to "roll" that board to give a less angular look? not a criticism just curious.
07 Dec 2020 20:04 #7 by crash happy
I believe you can roll the board by removing the paper on one side. I haven't tried it as this plan doesn't call for it. I actually like the sharp angles, gives it a bit of a stealth look. :woohoo: Here are the specs;
07 Dec 2020 20:34 #8 by paul d
oh blimey! it's a lot smaller than I thought! if you like stealth how about a f117 ?
08 Dec 2020 07:17 #9 by crash happy
"oh blimey! it's a lot smaller than I thought! "
I could reply to that remark in so many ways, but most of them would be unprintable ! :ohmy: :evil:
"if you like stealth how about a f117 ?"
No I don't think so. That would be going from ' slightly mean looking' to something that fell out of the ugly tree & hit every branch on the way down ! :blink:
Thanks: Eric, Klipkopwildlife, Quorneng, paul d
09 Dec 2020 14:53 #10 by crash happy
The last of the parts were cut, folded & glued today. I did a 'dry' fit to check everything lines up. Not everyone's cup of tea, but if that isn't one sexy looking aircraft I don't know what is ! :woohoo: [badass] I will start on the electrics tomorrow. I hope that bleedin fan turns up soon ! :pinch:
09 Dec 2020 15:03 #11 by Quorneng
Replied by Quorneng on topic FT Saab Viggen 70 mm EDF.
crash
That looks very nice.
How about the leading edges? A half round of balsa would not only give some 'ding' protection but would significantly reduce the power needed at cruising speeds.
It would also make a difference to the top speed but at full power such a design uses so much anyway you are unlikely to notice the odd mph or two!
09 Dec 2020 16:25 #12 by Eric
Replied by Eric on topic FT Saab Viggen 70 mm EDF.
I was watching a DVD, a short while ago, where a helicopter ran rings round a Viggen, and then shot it down!
Mind you, it was an old Airwolf vid! :-)
09 Dec 2020 17:11 #13 by paul d
looking good crash! agree with Simon about the l/e, presume those wings are "flat plate"?
09 Dec 2020 21:11 #14 by crash happy
I have been giving some thought to the leading edge & agree, it is going to need some streamlining & protection. Balsa would be my first choice. I will see if I can source some locally.
"I was watching a DVD, a short while ago, where a helicopter ran rings round a Viggen, and then shot it down!
Mind you, it was an old Airwolf vid! :-)"
Only in Hollywood ! :lol: MIG 25's wouldn't mess with it, so I don't think a helicopter would stand a chance ! :)
Out of interest; Swedish Viggen's regularly intercepted SR 71's flying the 'Baltic express route' in the eighties. One pilot had five confirmed missile locks. ;)
09 Dec 2020 21:32 #15 by supertigrefan
Replied by supertigrefan on topic FT Saab Viggen 70 mm EDF.
I love the Viggen, it is indeed a sexy aircraft. I own a car with the same badge and they named one of their models after the Viggen. As a cold war interceptor our equivalent was the Lighting and trying to make a comparison is difficult, same job but very different aircraft. I dare say that in the right situation a section of infantry could take one out but the infinitesimal odds make it pretty meaningless.
Thanks: Klipkopwildlife, paul d, crash happy
Time to create page: 0.860 seconds
