Depron Heinkel HE162
Small and light bolt 'pads' and 'nuts' specifically shaped to be glued into the wing and fuselage structure.
Two bolts close to the wing leading edge.
One at the rear on the wing centre line.
The front 'nut' under the wing mount and also glued to the fuselage skin..
The rear centre line bolt needed a 'bridge' nut to transfer the forces to the skin on either side.
Finally a first stress test. At close to the all up flying weight and supported by its wing tips.
As the nacelle sits on the fuselage all the weight is being transferred to the wing by just the three wing bolts.
That looks an interesting book.
From what I understand the BMW 003 jet was considered a weak design with little room for improvement in terms of both reliability and thrust but it was the only jet engine available for the HE 162. The rather more powerful and cheaper to produce Jumo 004 was reserved for the ME 262 and Arado Blitz.
I believe what is shown on that cover is powered by a pair of pulse jets similar to those used on the V-1. It was not surprising that Heinkel considered this as the pulse jets were easier and a lot cheaper to produce. The real drawback, apart from horrendous vibration, was a very high fuel consumption that was even worse than the early jet engines and a life between overhaul measured in minutes rather than the 20-30 hours of the BMW 003.
I doubt such a configuration would have ever been realistic given the Luftwaffe's poor field maintenance facilities and a chronic fuel shortage?
The three point wing fixing is simple, light and quite adequate but for other simple and light weight reason I really need to permanently build the motor nacelle on top of the fuselage. This would however make it impossible to access rear centre wing bolt.
I was just about to start to cut open the wing to insert additional reinforcement to enable two widely spaced rear bolts but it occurred to me does the rear bolt have to be perpendicular?
A bit of work with an adjustable set square indicated that if the bolt was angle at 55 degrees it just clear the nacelle although it might need a long screwdriver.
Creating holes in objects at specific angles other than 0 & 90 degrees is a bit of a pain, particularly in FreeCad so that was the task this morning,
5 hours later we have.
The angle of the bolt does indeed clear the nacelle.
When the fuselage is built up on the wing to meet the nacelle the bolt will be accesses via a long tube.
Once the bolts are removed the wing will be able to slid out sideways. As the wing is removed it will leave a large gap between the nacelle and the fuselage. This will be vital to give clearance for the down turned wing tip - I hope.
I think this means the end of the construction 'trial and error', or now it just needs doing.
- Thank you received: 14470
Not part of the issue but having the nacelle permanently fixed and a close fit over the wing w2ill give an element of fail safe if a bolt does 'let go'.
The next task is to build up the fuselage profile on the top of the wing so it is a close fit to the underside of the nacelle. More planking!
In a spare hour I have installed and tested the ailerons.
Remarkably tedious to do to get it to all line up exactly.
The hole that will be left when the wing is slid out.
The big question is will it be possible to get the down turned tip through. It is possible I may have to reduce the down turn a bit so it will!
The tips were added to limit a 'Dutch roll' effect usually the result of a strong roll stability coupled with a weak yaw stability which gives a 'tail wagging' effect without any control input. It will be interesting to see it any Dutch roll tendency can be detected.
- crash happy
- Thank you received: 1203
That is an interesting concept but as you surmised there would be some problems.
First the launching finger holes holes, if used, would not line up with the positions for the retaining bolts.
Second the preferred minimum layout for the wing bolts (2 at the front, a at the back) is the exact opposite of the preferred bolt positions for the nacelle.
Third the nacelle was designed to be glued in position so there are no 'built in' strong attachment points close to the motor to bolt anything to. Such strong points would have to be added and being close to the motor any extra weight would be rather far back.
A fixed nacelle with a 'slotted in' wing is not the easiest or the most elegant solution but it is probably the lightest and at the moment saving weight takes priority
I intended to place everything far forward in the nose. This means the servos in the elevator (2 coupled with a Y lead) have a seriously long (1.3 m) wire to the Rx which causes the servo to 'stutter'.
This video shows the effect. The left servo has a 2000 mm long wire the right has a 200 mm lead.
I originally thought it might be due to voltage drop but the difference between the ends of the long lead with servo running is only 0.02V.
It follows it must must be the signal that is being effected by wire length.
What is odd is the AN 124 elevator has two 5 g servos on a Y lead with a 1.5 m wire and that behaves quite normally.
Given that both servos behave the same way on the long servo wire suggest this stutter effect only appears significantly on the 3.7 g servo.
At the moment the only solution appears to be to mount the Rx directly under the wing so the aileron and elevator servo wires will be as short as possible.
Any thoughts?
