- Thank you received: 14473
tiger moth another Dumas
- old ugly
- Senior Member
- Thank you received: 236
- Magpie
- Thank you received: 1048
I didn't know about the geodetic fuselage of the Wellington etc.
Fancy building a model with that!
or
and many more.
A Barnes Wallace design as I recall.There's been some documentaries on the history of the RAF recently.
Its big advantage at the time was it created what in effect is a stressed skin structure that could be simply fabric covered.
There is the famous line in the Dam Busters film where Barns Wallace is pleading with the Air Ministry for authority to develop the bouncing bomb.
In answer to the question "Why should we believe you it is possible to design such a thing?". He replied "I did design the Wellington bomber" which at the time was the mainstay of Bomber Command.
However after the debacle of the Ministry sponsored and even bigger R101 is was held in storage, never flown again, eventually being scrapped in the 1930s.
Interesting "tit bit" the Americans were interested in the R100 and even offered to refill it with Helium for free in exchange for the design details, however at the time the "Special Relationship" did not go that far!
- old ugly
- Senior Member
haha
- old ugly
- Senior Member
- old ugly
- Senior Member
here is a wheel from the tiger moth. in this case it came black. i painted the inner rim silver and then used the sharpie to clean up the edge of the tire. just make sure the paint is real dry, draw on something with the sharpie before you do the wheel just to get the ink flowing, then go around the rim once and stop. make sure it is a good sharp point on that sharpie. it does a pretty good job.
i edited to show one of the infamous dumas red wheel. i did it the same way.
- Magpie
The best option I've found is to use laser-cut balsa hubs & fit them with an O-ring tyre.
I'm waiting for some more O-rings but here are some I made earlier.
The blue hub is the acrylic paint from my Gannet, the black is the tissue from the Lysander, the aluminium is kitchen foil.
I've just checked on the VMC site but they don't seem to be stocking them anymore.
Dimension wise the hubs are two laminated 18mm diameter 1/16th sheet, and an 18mm ID 4mm thick O-ring giving a 1 inch dia wheel.
