- Thank you received: 236
Dumas Lysander my try.
- old ugly
- Senior Member
20 Mar 2025 17:31 #1
by old ugly
Dumas Lysander my try. was created by old ugly
i start on the lysander a week ago. and i can see the issues Magpie had, i am working through them tho.
i have the fuselage structure complete. i have done a camo test panel with two colors of tissue that i think will work.
just starting on the wing which i am building in one pc just to try to keep them the same and will cut apart after.
the first day of spring, i hoping the snow shoveling is almost done but you just never know.
- old ugly
- Senior Member
22 Mar 2025 14:54 #2
by old ugly
Replied by old ugly on topic Dumas Lysander my try.
22 Mar 2025 15:29 #3
Replied by Quorneng on topic Dumas Lysander my try.
Nothing wrong with that!
The tissue looks excellent.
Thanks: Eric, old ugly
22 Mar 2025 16:55 #4
Replied by Klipkopwildlife on topic Dumas Lysander my try.
You're putting us all to shame sir. Wonderful work
- Thank you received: 10844
22 Mar 2025 17:20 #5
Replied by THE BLACKBIRD on topic Dumas Lysander my try.
Wow that is some modelling, superb, respect sir
Thanks: Eric, Klipkopwildlife, old ugly
- old ugly
- Senior Member
24 Mar 2025 01:51 #6
by old ugly
- old ugly
- Senior Member
24 Mar 2025 02:05 #7
by old ugly
- Magpie
- Thank you received: 1048
24 Mar 2025 12:09 #8
by Magpie
Replied by Magpie on topic Dumas Lysander my try.
The covering looks perfect.
How did you do the camouflage? Do you glue the green onto the base tissue & what glue? I did mine all black to make it easy, & didn't do all the details. I tried the cowling but it was rubbish so I left it off.
How are you going to do the final fixing of the wings?
Thanks: Klipkopwildlife, old ugly
- old ugly
- Senior Member
24 Mar 2025 15:44 - 24 Mar 2025 15:47 #9
by old ugly
Magpie,
Thank you for you comment.
For the camo i put on the light color tissue first and then shrunk it with water, Then I cut out camo shapes. i just laid the camo cutouts on the previously covered surface then with a small paint brush and a watered down solution of carpenter's wood glue i carefully brushed the solution around all the edges of the camo, (a thin line just to stick it down). then i water shrunk it again, i did the third color the same. but the third color is three layers thick and some of it didn't shrink as well. i don't think i would do 3 colors again. the issue with the way i did it is, a thin glue line is visable, i don't think it distracts from the effect.
This is the first time i did camo. i could not find any videos of how others do it.
The wings. i pre fitted the canopy. i pre fitted the wings. then i pre fitted the canopy and wings together. lots of fitting and adjustments to get them to sit correctly. then when i was ready to glue the canopy down i put the dowels through the canopy, slide the uncovered wings onto the dowels. then with the dowels, wings and canopy centered as an assembly i was ready to put that assembly onto the fuselage. i put a dab of 5 minute epoxy on the top fuselage platform rite where the dowels would sit. then holding my breath and all puckered up i put the canopy assemble onto the fuselage. (i sat and held the whole thing in my hands until the glue set, it took longer than 5 minutes) once the epoxy dried i slid the wings back off and covered them. final assembly, i CA'd the dowels to the end wing ribs. it took me a long time to think of how to do that and keep it looking good. there is no way to that i know of to get those wings to sit perfectly horizontal. it is all glued together and i think it came out pretty good.
The cowling, i cut out the paper section, rolled it up and taped it together, slid it over the front, fitted it, then glued it, it wasn't too bad.
I saw the issue you had with those inner wing ribs and addressed that rite off the bat. i carfully detached them from the sheet balsa, laid them on wax paper and soaked them with CA glue so they are stronger.
I thank you for you posts on your lysander. that really prepared my for what i was going to find.
All in all this is a kit that really tests your brain and patients.
OU
OU
Last edit: 24 Mar 2025 15:47 by old ugly.
Time to create page: 0.487 seconds
