Sig Four Star 60 build
15 Feb 2012 19:26 #16 by Eric
Replied by Eric on topic Re: Sig Four Star 60 build
Mr Moderator strikes again! :P
  • Dean M
16 Feb 2012 02:00 #17 by Dean M
Replied by Dean M on topic Re: Sig Four Star 60 build
Sorry everyone for my muck up here they are again in proper size (hopefully)
I nearly choked on my latte.
16 Feb 2012 02:01 #18 by Ex-Member
Replied by Ex-Member on topic Re: Sig Four Star 60 build
that looks impressive sir. :cheer:
  • Dean M
16 Feb 2012 02:07 #19 by Dean M
Thanks tony I am not quite up to your ability yet!!!!
Dean
16 Feb 2012 02:15 #20 by Ex-Member
looks ok to me, dont put yourself down sir. :cheer:
16 Feb 2012 14:06 #21 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: Sig Four Star 60 build
Not your muck up Dean, mine!:angry:
16 Feb 2012 18:32 #22 by Grumpy42
Replied by Grumpy42 on topic Re: Sig Four Star 60 build
It looks good to me Dean - don't be discouraged by the speed that Tony and company can build at, even an old fart like me - who has been building since about the time Adam was a boy, can't keep up with them. The next thing is to try building from a plan - start off with something simple and take your time. Avoid going for CNC cut components and cut everything out yourself - as Eric noted earlier if you bugger something up you can always alter it or make a new one.
16 Feb 2012 18:58 #23 by Ex-Member
good advice from grumpy. :cheer:
  • Dean M
16 Feb 2012 21:15 #24 by Dean M
Thanks,
The next thing I have to build is a Flair Puppeteer I also have a set of plans for a John Carpenter 80" Stuka, not sure whether to build something simpler from a plan before attempting the stuka.
All the talk of Lancasters on here has got me wanting to built a TN Lanc!!
Dean
17 Feb 2012 06:17 #25 by The Beard
Replied by The Beard on topic Re: Sig Four Star 60 build
That looking a really nice model Dean and its coming on well ,congratulations.Is it going to be IC or electric
17 Feb 2012 06:19 #26 by The Beard
Just reread your thread and see your fitting a proper engine well done Dean.When you quote the engine do you mean .65 being an OS 46 LA?
17 Feb 2012 06:32 #27 by Grumpy42
Dean M wrote: Thanks,
Dean
I wouldn't attempt the Stuka or a Lancaster as your first build from plans project Dean. My recommendation would be to try for one of the older "Classic" designs - something like my Powerhouse or perhaps a Senior Telemaster. they are basic designs - well proven and a good grounding in building techniques without getting to complicated. Warbirds are very attractive but they always seem to come up with some problems that require experience to solve. Note Tony's problem with the retracts and BB's problem with the EDFs
  • Dean M
17 Feb 2012 13:48 #28 by Dean M
The Beard wrote: Just reread your thread and see your fitting a proper engine well done Dean.When you quote the engine do you mean .65 being an OS 46 LA?
Hi it is a .65LA this is in the middle of the recomended engine range suggested.
Dean
  • Dean M
17 Feb 2012 13:54 #29 by Dean M
Hi Grumpy,
That is my thinking really, I keep looking at the Stuka plan thinking how the cluck to I get an aircraft out of that!!!!!!!!!!!
What about one of the Ben Buckle range? I quite like the plan for the 78" Elf biplane.
Dean
17 Feb 2012 19:04 #30 by Grumpy42
G'Day Dean,
I think you would be best to avoid looking for extra complication for your first "off the plan" build. The Elf is a biplane and that adds the extra complication of building the extra wing - and then getting all the angles of incidence and general rigging right. If I might make a suggestion go for something that is fairly big, simple and only has dihedral to incorporate - once again polyhedral and rigging a biplane adds complication - I'm not all that familiar with Ben Buckles plans but I had a look at the website and checked out a few plans - my suggestion? The Junior 60 - it is simple - has only one wing - with dihedral and the added advantage that at least one member on this forum has built one - local knowledge and plenty of help. That's my tuppence worth anyway.
Cheers
Time to create page: 1.131 seconds
