Avro D 1911 biplane
  • ether823
  • New Member
  • New Member
24 May 2021 16:05 #1 by ether823
Avro D 1911 biplane was created by ether823
I wonder if anyone has a set of plans for a Avro D 1911 biplane 1/6th scale (62") going cheap please. Many thanks, Peter
24 May 2021 19:10 #2 by paul d
Replied by paul d on topic Avro D 1911 biplane
Not sure such a plan exists Peter, there is a chap on the web offering a 1/4 scale plan.
  • ether823
  • New Member
  • New Member
25 May 2021 17:01 #3 by ether823
Replied by ether823 on topic Avro D 1911 biplane
Just been in touch with www.model-plans.co.uk and I am now the proud owner of a set of 1/6th scale plans. Whoopee. Cant believe my luck. £13.75 including postage. The same set of plans from the USA would set me back about $65 including postage. (£46.00). Peter
Thanks: Klipkopwildlife, Flytilbroke, THE BLACKBIRD, paul d
25 May 2021 18:05 #4 by Klipkopwildlife
Replied by Klipkopwildlife on topic Avro D 1911 biplane
Thanks for the link Peter, useful one, perhaps we can get some pictures of the build?:)
  • ether823
  • New Member
  • New Member
04 Jun 2021 18:42 #5 by ether823
Having a look at the plans and there is a jig to make the wings but for the life of me I cant work it out. I have included a copy of the plan. All ideas most welcome.
05 Jun 2021 08:27 #6 by Eric
Replied by Eric on topic Avro D 1911 biplane
Sorry, I don't see any drawing - just two blank white squares.
05 Jun 2021 09:21 #7 by Klipkopwildlife
Ditto
  • ether823
  • New Member
  • New Member
05 Jun 2021 10:18 #8 by ether823
Strange I can see the plans, are you using adobe reader
  • ether823
  • New Member
  • New Member
05 Jun 2021 10:21 #9 by ether823
try this file
05 Jun 2021 12:28 #10 by Klipkopwildlife
I still get nothing. Can I suggest,doing a 'PrtSrn' which puts the screen on the Clipboard, then go to Paint, click Paste, then save it as a jpg. Then use "Attachements", "Add Files", "Insert". The allowed file extensions do include .pdf
  • ether823
  • New Member
  • New Member
05 Jun 2021 15:18 #11 by ether823
05 Jun 2021 16:57 #12 by Eric
That worked.
I see a severely undercambered right? wing panel, but no jig that you mentioned.
That section will be very difficult to build, and very prone to warping, as it is so thin.
I think the easiest way would be to pin the bottom spar right on the edge of your building board, and let most of the trailing side hang in free space, just the front 'box' on the board to keep it straight - but of course the thin ribs would be very vulnerable to accidental damage from a careless waved hand or passing cat (if you have one!)
  • ether823
  • New Member
  • New Member
05 Jun 2021 17:26 #13 by ether823
the jig is at the bottom of the drawing
  • ether823
  • New Member
  • New Member
05 Jun 2021 17:34 #14 by ether823
there are no ribs to speak of, a typical section is bottom capping, the leading edge then a spar and then a infill piece of 3/32 balsa in the middle then another spar then some top capping . I was wondering if you laid all this up in the jig as a sandwich maybe.
05 Jun 2021 19:25 - 05 Jun 2021 19:32 #15 by paul d
The idea is you make a board to the shape given and build the wing on that, you have three choices from my point of view, build the jig ( you would need to make a profile gauge from the drawing first) redesign the ribs so there solid or cut two of the jig patterns shown and use them to cut a foam jig.
should make a wonderfully light wing.
Edit: I would use spruce for the cap strips, you'll have a devil of job covering it if you use balsa.
lovely project, please keep us all informed of progress, in fact why not start a build thread in the appropriate place on the forum?
Last edit: 05 Jun 2021 19:32 by paul d.
Time to create page: 0.567 seconds
