MosFet
10 Oct 2012 14:12 - 10 Oct 2012 19:29 #1 by Klipkopwildlife
MosFet was created by Klipkopwildlife
A FET, more correctly a MosFet is a 3 terminal device that supplies current to the end user, typically, but not exclusively the motor that turns the propeller.
The terminals are gate, source and drain, the gate switches it on (and off), the source is the battery and the drain goes to the motor. Unlike transistors which have a voltage across them when switched on (.6v for Silicon) a MosFet has a forward resistance measured in mohs (millionths of an ohm). This means that a relatively small device can carry hundreds of amps with ease.
This little guy can hold back 55volts, and allow 100amps through without even breaking into a sweat!
Last edit: 10 Oct 2012 19:29 by Klipkopwildlife.
Thanks: admin, Sarah-Jane Smith
10 Oct 2012 16:23 #2 by The Beard
Replied by The Beard on topic Re: MosFet
And now Im confused where is all of this I assume its part of the ESC we dont need to worry to much about as it takes care of itself.
10 Oct 2012 18:56 #3 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: MosFet
Dead right Stephen, it's just that when a question is asked I try to make sure there's some kind of entry in the Technical section. There's no such thing as a silly question, only silly answers!
10 Oct 2012 21:07 - 11 Oct 2012 14:53 #4 by The Beard
Oh that bit is clear as mud now I normally thow it away :whistle: :whistle: Now I know why my leccies dont run ,thought it was the little tiny starter motor.
Last edit: 11 Oct 2012 14:53 by Klipkopwildlife.
Time to create page: 1.058 seconds
