SD card
16 Jul 2019 17:25 - 16 Jul 2019 17:26 #1
SD card was created by Klipkopwildlife
SD cards, more correctly micro SD cards are now being used in some types of radio. Most people fit 16Gb class 10 but the average model file is only 2Kb so even a 4Gb card will be good to carry thousands of models. The class number is the speed, important for cameras but for our purposes older low speed varieties are quite adequate. The radio only reads it once when you switch on or change models. Do use a USB card adapter it saves confusion as to which logical drive you want to use.
Windows will quite happily Format the card prior to use although most don't need it. If you do Format it use Fat 32, nothing else will work.
Last edit: 16 Jul 2019 17:26 by Klipkopwildlife.
16 Jul 2019 18:45 - 16 Jul 2019 18:56 #2
Replied by Eric on topic SD card
Any clue what the widget is called? - - - -
Doesn't matter - found loads on e-bay. £3.50.
Last edit: 16 Jul 2019 18:56 by Eric. Reason: added a comment
16 Jul 2019 22:43 #3
Replied by Quorneng on topic SD card
"USB 2.0 memory card reader adaptor for micro SD cards"
99P inc post on Ebay if you hunt about!
17 Jul 2019 17:43 #4
Replied by Klipkopwildlife on topic SD card
I suggest you buy another SD card as well![badass]Eric wrote: Any clue what the widget is called? - - - -
Time to create page: 0.650 seconds
