- Thank you received: 10844
Laser cutter
21 Oct 2019 09:17 #1
Laser cutter was created by THE BLACKBIRD
I see on model flying forum theres a laser cutter being talked about that looks very good for the price
£118 off bang good, if i could use a computer i think i would get one
its a good sized bed on it
21 Oct 2019 11:09 #2
Replied by Klipkopwildlife on topic Laser cutter
Be a bit careful Tony, it's an engraver, which means it only really marks the surface, to cut would require many passes to get through. I have been experimenting with Laser cutting and I found the problem is getting the Laser far enough away from the work piece. I found about 6feet! to be fairly ideal for cutting! It's all to do with the focusing, too close to the laser emitter means you have a very tapered beam which tries to make a V cut.
21 Oct 2019 13:40 - 21 Oct 2019 13:42 #3
Replied by THE BLACKBIRD on topic Laser cutter
I had no intention of buying one Klipy as i could not work the computer, so its no good for our purpose, sorry if i gave wrong info
And iv just burnt my bloody face with a blowlamp
Im going back to bed:sick:
Last edit: 21 Oct 2019 13:42 by THE BLACKBIRD.
21 Oct 2019 14:26 #4
Sorry to hear that Tony. Not wrong info from you, wrong info from the other side!. I think it's time you got into computers, you would really enjoy a computerised router, and, with a high speed motor you can cut all manor of formers and ribs accurately using a 2mm cutter.
21 Oct 2019 14:54 #5
For some strange reason i dont like computers, i cannot ecplain it
The only time ill sit at a computer more the ten minutes is if im watching a film
I like hand cutting things out, gives me a lot of satisfaction to see it come together from sheets of wood,
Thanks: Flytilbroke
Time to create page: 0.448 seconds
