- Thank you received: 197
Incidence gauge
- Pylonuk
- Premium Member
Are you sure about that Eric?
B.
- crash happy
- Thank you received: 1203
The angle of incidence of a wing is fixed. The angle of attack is variable. Decalage, is the relationship between the angle of incidence of the wing & the horizontal stabiliser ?
- supertigrefan
- Thank you received: 513
Eric wrote: If your wing is at zero aoa, then you have no lift being generated!
.......only if the airfoil is symmetrical, if not the airfoil will still generate lift at zero AOA, even if only a little.
- crash happy
- Thank you received: 14470
The centreline runs from the extreme front of the leading edge - to the (theoretical) point of the trailng edge.
So with the flat bottom at zero, you really have a few degrees of positive aoa relative to the tailplane.
With a fully symmetrical section at 0 aoa, it is generating lift equally up and down - sum total of zero lift.
The aoa is controlled by the elevator.
With a perfectly trimmed craft with a fully symmetrical wing, and thrustline at 0 as well, it should need NO ele trim or deflecton - either way up - to track a straight line.
But of course, being heavier at the front than the back, gravity alone will cause the flight-path to be a parabola - groundwards!
Throwing in the difference of incidence between top and bottom wings of a biplane is just confusing the issue. Try figuring out the individual aoa of each of a triplanes wings, then figure out the AVERAGE aoa of the combination.
Your right crash this one is designed for a specific flight profile and I just wanted to get it set up "sort of correct" from the get go.
I have downloaded a app and I've got a idea to make a crude gauge...I'll report back.
All the profile does is set the AMOUNT of lift generated for a given aoa. (disregarding airspeed for now!)
Try flying an undercambered wing inverted! :evil:
Eppler 374 looks like a semi-symmetrical section - until you look at the camber line, I can't recall the proper name for the individual measurements taken from the centreline, to give the profile, right now - but 374 is an undercambered section popular with slope soarers, as it gives high lift the right way up, and good lift inverted, while remaining slim enough for good penetration.
A very thin profile, heavily undercambered section is very draggy, as well as being very weak, structurally.
Model Aircraft Aerodynamics, written by Martin Simons.
The isbn is - 1 - 85486 - 121 - 2
My copy is dated 1994, so there may be later versions out there.
- supertigrefan
NASA
- supertigrefan
Eric wrote: -
AOA is adjusted by the elevator, but it's set by the incidence.
Anyway, this started off as a question about incidence meters and is heading towards being dominated by aerodynamics..
- Pylonuk
- Premium Member
In the attached scan, you can a flat plate aerofoil and at 0 degrees angle of attack there is 0 lift.
On the right of the scan there is another graph for Gottingen 419, this shows the lift being created at a 0 angle of attack, you can see that you need to fly that section at some negative angle of attack to get 0 lift.
Lift is the vertical scale angle of attack is the horizontal scale.
The scan is from the book that you cited.
Regards
Barrie
Acording to my calculations the thick end of the wedge needed to be 7.1mm, best I could manage was 7mm! that'll do I think?
using the phone app it seems about right.
Only joking I am sure it will be fine.
