- Thank you received: 1192
3D printed props
- jon.in.swansea
Hints: rotate the prop for printing. If you print with the shaft vertical you have a lot of cleaning to do. The Prusa slicer software allows one to paint on support locations (see the blue dots on the upper left). This results in just enough support. If you ask for supports 'from the build plate' you get lots more and they are difficult to remove. I increase the support Z gap by 0.05mm and the supports tend to pull off easily.
Light sanding with P600 is usually all that is required to tidy the edges. I paint a bit of correction fluid on the front for ease of identification in the field. As printed these beasties are not quite balanced. I have a simple rig for balancing and I find that adding a bit of electrical tape is faster and works as well for me as sanding down for getting a balance.
I only had one pop on me at an early stage of learning how to print and balance. I have a habit of testing every other prop I print - it goes on the model and gets ~2/3 throttle. I use prop-savers - some motors come with them, otherwise I have a prop-saver that I print as well (adapting as needed for the motor shaft and the prop). I keep a 2-3 spares in my field box - especially if it is a maiden session or I have not quite got the feel of the model. Sometimes I will swop the one shown in the photos with the 'slow' variant to see if that has a better feel on the day.
I am happy to share the STL file and or the Prusa .3mf file but those are rather large for the upload facility. Suggestions? -Jon
- Thank you received: 14470
- jon.in.swansea
APC 7x4 (178mm) 2cell ~half throttle = 86g top = 190g thrust,
3cell half throttle = 122g top = 350g thrust
175mm 'slow-fat' printed prop 2cell ~half 84g top = 190g thrust,
3cell ~half 134 top = 272g thrust
186mm 'slow-fat' printed prop 2cell ~half 82g top = 176g thrust,
3cell ~half 130 top = 300g thrust
180mm normal 8x4.5 printed prop 2cell ~half 48g. top = 134g
3cell ~half 80g top = 244g
195mm normal 8x4.5 printed prop 2cell ~half 68g. top = 174g
3cell ~half 126g top = 290g
The 180 normal printed 8x4.5 does not do so well at upper revs. The 'slow-fat' wins on thrust if I am running on a 2cell (saves some weight. I like to start with 2cell and then move to 3cell after I am a bit more comfortable with flight characteristics). With printed props I rarely go much over half throttle - briefly on launch. The exception are pushers as the prop diameter is less and they seem underpowered.
The APC is quieter and provides more thrust.
-Jon
A bit of fine glasscloth is your friend! Apply gently to the trailing edge!
Interesting but the really important figure for most electric flying is the thrust/W figure (thrust efficiency) rather than simply the maximum thrust obtainable. You do need a Watt meter to determine it.
It would be most interesting to compare the efficiency of a printed prop against a moulded one.
With electric you can't really afford to 'squander' power, the battery is just too heavy, whereas with IC you can and in practise have to simply to make the prop strong enough to withstand the cyclic loads the engine generates.
As Simon put, this is a vital tool for electric flying, as it tells you whether you are asking too much from the motor/battery/speed controller combi.
Used with your thrust gauge, it will show how much tractive effort the prop is putting in AND how hard the motor etc are working to achieve that.
In turn, that will give you an indication of useful flying time for that combine, and if something is working at 100%, and about to release the magic smoke!
In case you hadn't realised it, a motor has a designed rpm/volt figure, the kv, and if loaded ( with a prop, etc) it will ask for more and more amps from the battery/speedo until it achieves this, or something fails - the motor windings melt, the speedo goes pop, or the battery simply cannot deliver, as it exceeds it's max safe current. (the C rating)
Then if that happens, you could have a nice bonfire on your work-bench.
It is generally accepted that the speed controller should be able to deliver between 25 and 50% MORE than the motor could ever demand, to avoid it becoming a very expensive fuse!
it's a balancing act.
- jon.in.swansea
Obviously the components are not connected, but are laid out as if they were. The white cone represents the receiver, and the speed controller is plugged in to the pins marked 'throttle'.
My Watt meter set up and its actually running!
Note the use of a servo tester to work the ESC to run the motor. Very simple. No radio is required. I use Deans connectors.
A close up of the Watt meter.
Running at low power, 0.42A, 8.17V (a charged 2s) using 3.4W.
This rig is for testing the amps and the balance of props. It does measure thrust.
- jon.in.swansea
If you are using that type of servo tester note its servo signal output is connected to both the input and output centre pins so although the ESC is connected to the "input" side, so it powers the servo tester, the tester also provides a 'signal' that will control the ESC.
Just be careful not to select "auto" as it will then cycle the motor repeatedly from zero to full throttle. :woohoo:
