Prusa Mk 4
No PTFE tubing here, that filament tube is very long
The drive system is some kind of epicyclic gear box.
Some kind of lever
Rollers
From the grooves in the bearings I would guess a pinch system for the filament
The round object below the grease tube is the guide for the sun and planet gears, I tried to assemble the gear box without it, you can't.
And the finished article, it happened so quickly and you daren't let go until the screws are in so the camera didn't get a look in.
This is the Nozzle plus the heater and thermistor
And there it's all together, the nozzle is cleverly held in with 2 thumb screws, a fact that escaped me for a while, it kept dropping out!
The fan on the left is kept closed by magnets, you flip it open to access the thumb screws.
On to the heated bed and Y axis, it's a Prusa proprietary item (so probably expensive to replace) The top surface is magnetic.
Only 3 bearings and simply attached with a rubber mat between the bearing and the carriage.
Note the rubber feet in the X extrusion.
and the top side
Only the centre screw is solid, the other 8 mountings are expansion joints!
all done
Finally I downloaded the latest Firmware file to a stick (supplied) and plugged it into the USB socket of the control panel.
Always a moment of trepidation when you switch something on for the first time
What an anticlimax, the screen said loading and then wanted to do a first time test. What could I say?
The printer then proceeded to drive the axes (axises) up down, left right, in out. There are no end stop switches, it's all done by current on the motor drivers.
Even the fans get checked
You get asked to put some filament in, then take it out again and finally tap the nozzle
Once the check was done I decided to try a test print, there was a file on the thumb drive for a key chain label, I just pressed the button and off it went, bed leveling all done for you at 9 points on the bed. When the bed had cooled I tried to get the label off the PEI plate, phew, talk about baby poo and blankets, I really battled, eventually I had to remove the PEI plate and bend it to release the part.
First print video is here
If you think about it using motor current to determine the limits is actually a cost effective way of doing it as It saves the wiring to the micro switches. Presumably it also provides some jam protection as well.
The A8 has no top limit switch. It does recognise that the highest possible print is 240 mm but when it finishes it leaves the bridge at that height. You have to remember to drop the bridge before starting the next job or it will automatically try to raise it by 10 mm to ensure the nozzle is clear of the bed! First time it stalled the Z motors and lost the step count so the manually set bed clearance was also lost
