MY NEW MODEL ROOM AND HANGER
10 Feb 2016 15:17 #121 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic MY NEW MODEL ROOM AND HANGER
Over the top ??? to big or to small why probs above ground ??
10 Feb 2016 18:56 - 10 Feb 2016 20:38 #122 by Garry Pollard
Replied by Garry Pollard on topic MY NEW MODEL ROOM AND HANGER
I would say too big Tony, and I would think that it would be too easy to sabotage being in full view
May be way off though
Last edit: 10 Feb 2016 20:38 by Garry Pollard.
10 Feb 2016 19:06 #123 by THE BLACKBIRD
I would not have thought you could be to big with the cable, 6mm twin and earth is not that big, don't think I will be getting any trouble there Garry very rarely see anybody, its lovely
Made the door for Nats shed fitted it and finished the boarding inside and out, got to rig her a light in there
Went to get the roofing materials yesterday afternoon but they are not ready yet, so will work on the hanger tomorrow
Thanks: Garry Pollard, Klipkopwildlife, Quorneng
10 Feb 2016 19:41 #124 by one tenor
Replied by one tenor on topic MY NEW MODEL ROOM AND HANGER
Hi BB nice work but may I suggest you ledge and brace that door for warp resistance and stiffness .just a thought
11 Feb 2016 05:56 #125 by THE BLACKBIRD
Was going to, just want to get her in and off my back so I can get on with the important shed :evil:
11 Feb 2016 07:10 #126 by Klipkopwildlife
Replied by Klipkopwildlife on topic MY NEW MODEL ROOM AND HANGER
THE BLACKBIRD wrote: Over the top ??? to big or to small why probs above ground ??
Just the way I would do it. 6mm2 is seriously large and therefore expensive. Conduit tends to attract all manner of garden implements that want to do it serious damage, and it tends to collect water in the low points which can give trouble 3 or 3 years down the line. The KISS principle is always best! :)
11 Feb 2016 12:49 #127 by THE BLACKBIRD
I would not have thought 2.5 mm twine and earth was big enough on that length from house to shed
The conduit will be above ground fixed to the fence for the most part
11 Feb 2016 17:31 #128 by Klipkopwildlife
40M isn't that far, the supply to my workshop is over 70M. It drives my big 1.75 compressor quite happily. The lights flick when it comes on. However the compressor won't start if the lathe is running and visa versa. I just have to be aware.
Plus, there is less maximum current limitation in a buried cable than above ground or cable track. You need to talk to a sparky who's got the book of words!
11 Feb 2016 18:14 #129 by Eric
Replied by Eric on topic MY NEW MODEL ROOM AND HANGER
I notice you are using chip-board boarding. I hope you realize that when this stuff gets wet, it swells up, then goes soggy and collapses! I know it doesn't rain much in Cyprus, but - - - ! :evil:
11 Feb 2016 20:28 #130 by THE BLACKBIRD
And some more done, the boarding is made to go outside, used a lot over here
11 Feb 2016 20:35 #131 by Ex-Member
Replied by Ex-Member on topic MY NEW MODEL ROOM AND HANGER
That is going to be a humongous workshop sir.
Fantastic work. :) :) :)
don't let the knockers get you down BB. :cheer:
11 Feb 2016 21:05 #132 by one tenor
That is not chipboard .It is Sterling or oriented strand board and is far more weather resisitant than chipboard especially when painted or varnished. It is often used a hoarding board around building sites and weathers quite well . I think you have chosen well BB Good luck once more
11 Feb 2016 21:37 #133 by one tenor
In U.K. supplying an outside shed has to be in 10 mm If I remember from when we installed fuel economy controls for boilers installed in out buildings or hut/sheds A copy of the relevant regs should be available in the public library Do you get enough wind to make a turbine worth while? .Or can you use "a genny "?
12 Feb 2016 01:16 #134 by Quorneng
Replied by Quorneng on topic MY NEW MODEL ROOM AND HANGER
And it even has a verandah for afternoon tea and cucumber sandwiches! ;)
12 Feb 2016 05:26 #135 by THE BLACKBIRD
Nobody is knocking Tony all good advice and trying to be helpful :)
Thing is im not getting any modelling done, my body has had enough when I get home, I walk the dogs then rest it
Old age is crap, like Garry the body cannot keep up with the mind :(
Time to create page: 1.555 seconds
