Basic model
29 Feb 2016 18:11 - 29 Feb 2016 18:17 #31 by Ex-Member
Replied by Ex-Member on topic Basic model
Ribs
Ribs
Ribs
Ribs
and
yup Ribs
enough ribs for five wings now.
Duster, diamond, double diamond and the dagger.
Last edit: 29 Feb 2016 18:17 by Ex-Member.
29 Feb 2016 23:36 #32 by Quorneng
Replied by Quorneng on topic Basic model
Could be a bit of a sod if you find you need to change anything when you build the first wing! ;)
02 Mar 2016 17:32 #33 by Ex-Member
Well i have started the wing today.
so far all the ribs i pre-cut have fitted perfectly :P
i had to roll the leading edge slightly so it would match the curve of the ribs for gluing.
when my lite ply turns up i can make thee dihedral braces and run the servo wires ready for the top sheeting to go on.
03 Mar 2016 17:29 #34 by Ex-Member
well today i made the dihedral braces and glued the two wing halves together.
then i sheeted the top of the wing with some 3mm Depron.
need to do the tips and ailerons next and then it can be covered and painted.
that just leaves battery box, u/c, final fuselage sheeting and the motor/esc.
nearly done ready for crashing.
:P
04 Mar 2016 18:22 #35 by Ex-Member
Wing tips designed and built.
need sanding next.
cant do the ailerons until i get some control horns, need more tissue and polyc as well, my daughter used the last of mine up. :angry:
05 Mar 2016 18:25 #36 by Ex-Member
well not much to report today been rebuilding bedroom walls instead.
still we can have a pose picture of the two models together. :P :P
18 Mar 2016 19:11 #37 by Ex-Member
covered the wing yesterday and decided that i would slop a bit of paint about this afternoon.
20 Mar 2016 16:24 #38 by Ex-Member
Painted the underside of the wing today and added the name.
20 Mar 2016 16:35 - 20 Mar 2016 19:30 #39 by one tenor
Replied by one tenor on topic Basic model
Not just Dad's taxi then but Dad's modeling supplies as well eh! Is she building planes as well then ?
Last edit: 20 Mar 2016 19:30 by .
14 Apr 2016 20:34 #40 by Ex-Member
battery box is sorted
ailerons made and fitted, just need painting
got the u/c to make and the motor/esc to buy and fit.
will be finished this month,
15 Apr 2016 00:10 - 15 Apr 2016 00:33 #41 by one tenor
Very nice Tony. How are the DD and the high wing job coming along ? BTW Tony did you get a big cardboard box yet? It can make a spray booth. If it is big/deep enough it will contain 99% Of the spray
Last edit: 15 Apr 2016 00:33 by one tenor.
17 Apr 2016 11:17 #42 by Ex-Member
Finished of the last few bits to this this morning.
ok i need a motor/esc and servos now and i can put this one to bed.
17 Apr 2016 18:15 #43 by Quorneng
I was actually rather hoping you might fly it. :P :P
19 May 2016 18:50 #44 by Ex-Member
I finally had enough money to order the motor, esc and servos for the duster.
they turned up this morning and i have managed to fit the motor and servos.
need some 3.5mm bullets so i can wire up the esc.
so this one is nearly finished at last. yaaaaaaaaaaaaaaaaaaay.
28 May 2016 12:59 #45 by Ex-Member
another on done, just about. :P
Time to create page: 1.150 seconds
