SR71 Turbine powered
20 Jun 2017 14:18 #1 by THE BLACKBIRD
SR71 Turbine powered was created by THE BLACKBIRD
I will be starting on a new build of this great aeroplane after two ill fated attempts
The first one a EDF caught fire taxiing out for its maiden flight and was totally destroyed
The second was being built with depron,which I soon found out I was no good with it, so it went out the first floor window
I have the plans again thanks to Tony, which I think will have to be enlarged because if I fit one turbine then the rear of the fuselage will be compromised with the thrust tube, and the ones I have seen done that way do not look right
So I will use the two turbines I have which will seriously overpower it being a very streamline model
So a 50 per cent increase will take it to 3.6m long and 1.8 m wing span
With 200 N or 44lbs of thrust
Should be starting around September
Thanks: Eric, Quorneng, blue123, old fart, boz, Squirrelnet
20 Jun 2017 22:20 #2 by Eric
Replied by Eric on topic SR71 Turbine powered
Third time lucky, BB! :woohoo:
21 Jun 2017 05:10 #3 by boz
Replied by boz on topic SR71 Turbine powered
Can't wait, :)
21 Jun 2017 10:11 #4 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic SR71 Turbine powered
Ha Ha don't mention luck Eric all mine seems bad, but yes I hope this one gets the job done
Looking forward to it
Thanks: Eric, boz
21 Jun 2017 18:30 #5 by THE BLACKBIRD
Got a 1/72scaie SR71 in the post today, a nice surprise ,my son bought it for me
So now I can see all the detail which makes scratch building better and easier,
I hope
Thanks: blue123, boz
23 Jun 2017 17:13 #6 by The Beard
Replied by The Beard on topic SR71 Turbine powered
you like a challenge BB
22 Jul 2017 08:54 #7 by nit23s
Replied by nit23s on topic SR71 Turbine powered
Hi BB,
Which post did u find the SR71 1/72 scale plan ?
05 Aug 2017 18:10 #8 by boz
BB, how are you getting on with this project?
After your bad luck I hope you will be getting underway with this soon.
Give us all a treat from your "little shed"
Boz. :)
19 Aug 2017 09:26 #9 by bond007mas
Replied by bond007mas on topic SR71 Turbine powered
I've got the plans for the sr71 1:10 scale with single turbine down the fuz p160
19 Aug 2017 09:37 #10 by bond007mas
Thanks: boz, Firewood
19 Aug 2017 13:56 #11 by bond007mas
Hi Tony
I tried to get some pics for you but no go
19 Aug 2017 15:14 #12 by boz
Have I missed something on this thread, I thought it was BB,s thread?
Welcome bond007mas,
Will you be building the sr71 from scratch?
Boz :)
19 Aug 2017 15:30 #13 by bond007mas
Yes and no. I sent the plans to Slec, they converted them to computer and cut out formers in ply and sent them both back, so I've got the plans and wood to finish the job
1:10 scale
19 Aug 2017 15:32 - 19 Aug 2017 18:25 #14 by bond007mas
Hi
Attachment not found
Last edit: 19 Aug 2017 18:25 by .
19 Aug 2017 16:49 #15 by boz
Wow that's a big un, :woohoo: boz
Time to create page: 0.955 seconds
