- Thank you received: 14470
Saturn 2.4 radio
After scouring the internet looking for a solution, I was told by Slough Radio Models that this is how to re-bind it.
If the below does not help, try calling Ripmax customer services as the binding process can be flaky
Whilst holding the small button down in the receiver, power up the receiver, the LED should blink fast, not a slow steady blink, then release the small button
Press and hold the bind button on the front of the transmitter, whilst switching it on. Be careful not to release the bind button accidentally during the process
The receiver should bind whilst the bind button is being held, if it does not, release and re-press the bind button on tx whilst everything is powered up
Answers on a postcard to E Bray, care of Saturn. :evil: [badass]
I've tried, and tried, and tried, but it simply will not re-bind.
The transmitter is transmitting, because although I don't have any audio receiver that will tune 2.4, I can tune 1.2, and I can hear the tx burbling away when the scanner is close to the transmitter.
So I can only assume that the receiver has gone deaf.
Interestingly (to techno-types!) The toy tx audio sounds like a mis-matched twin plane in the distance, ie rurrarurrarurrra.
The Spekky makes a much faster but regular burring noise, and
The Futaba a higher pitched burr, so I'm assuming it has a higher frame rate.
Unlike with the old-style 27 and 35 Meg trannies, there is no change of tone when you move the sticks about.
I'll have to try to make an RF probe that works at these high frequ's, so I can see it on the sillyscope.
Eric wrote: The Futaba a higher pitched burr, so I'm assuming it has a higher frame rate.
/quote]
That's because it's pulse width changes, the frequency then remains the same.
- Crashrr
- Senior Member
- Thank you received: 284
Most grateful for any help as the last RC system I owned was a MacGregor one channel non-proportional system in 1973...
Many thanks,
Crashrr.
- Squirrelnet
- Thank you received: 2067
I am the other way round. Was given the 6CH Rx but no Tx. However I know where to find one when the time is right
The rx I had worked better after I'd put it in a bench vice, and wound the handle up really tight! :evil:
I think I used the tx for spare parts for something else.
p.s. this thread IS nearly five years old! [badass]
